Question about Toshiba Televison & Video
TOSHIBA SDV290 U WON'T ACCEPT THE DVD WON'T EVEN READ IT OPENS BACK UP
    Guru:
  • 859 Answers
This usually means your player, has in effect and reality rejected your DVD for some reason.
You can read the many reviews of this unit at videohelp.com by following this link.
My guess is if its not one of the recorded types that causes problem your player is defective on arrival and should be returned to your place of purchase and describe your problem.
Sorry to bear the bad news.
Regards,
Worldvet
Posted on Jun 19, 2008
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
Won't read dvd
The most common cause for this is a dirty or bad optical pickup in the unit itself.
Dec 20, 2012 | Audio Players & Recorders
The DVD player won't accept any discs
tried first with cd lens cleaner, if can not get with cleaner you can do the manual lens cleaning. using with the fiber cloth soak small amount of alcohol then apply cleaning the lens. make sure before do this unplug the unit and do this gently not to damaged the lens.
Aug 30, 2012 | Toshiba Televison & Video
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
CD/DVD Drive won't accept new blank CDs and they jam in the computer. I have to restart the computer (sometimes more than once) to get the machine to eject the discs.
The problem would be the dvd rom, it won't read anymore. That's a problem with a combo DVD rom, when it being use frequently it tends to breakdown, mainly the problem is the internal parts. I have tried repairing most DVD/CD Roms, to no avail..... mostly the problem would be the parts, and it is not available in the market, and it is better to buy a new one than getting it into the manufacturer's service center, they charge excessively like your buying a new one!
If the CD is stuck inside, get a pointed metal rod, there is a small hole in the face front and push the rod into that hole untill it opens the cd tray.
Thanks for using FixYa!
Jul 04, 2011 | Apple 20" iMac Desktop
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
I am going out of my mind trying to dub VHS to DVD on my new Toshiba DVR620. Please help!
I have a Toshiba HDD&DVD vcr RD-XV48DTKB will not accept disc or play any disc have tried several makes even new ones it just loads then says error cannot play eject will not play or record HELP
Jan 22, 2011 | Toshiba DVR620 DVD Recorder/VCR
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
Toshiba RD-XS35 DVD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Televison & Video Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
