Question about HP Photosmart M447 Digital Camera
Sand in camera
Lens will not extend and it tells me an error code m440-33 and the lens error tells me to turn the camera on and then off again and yet it still does not work
  • Anonymous Aug 23, 2008
    I can hear the lens gears move, or grind, or try to open, but they do not. then I get this error message: "M440-33, go to hp.com"...but there is no help there.
    So apparently there is some guck, dirt, sand..(i live in the desert)...in the lens' mechanism, or, the gears are broke. The gears, or whatever it is, the electronics, that open and close the two lens/shutter windows.
    Probably cheaper to just buy an new cam. Right?
    Thanks
    RLM
    Phelan, Ca
  • Anonymous Mar 31, 2009
    MI CAMARA AL MOMENTO DE TOMAR UNA FOTO O VIDEO ME MARCA UN ERROR EN LA PANTALLA QUE DICE ERROR DE OBJETIVO INTENTE APAGAR SU CAMARA Y VUELVA A ENCENDERLA Y LA LENTE PARECE HACER ESFURZOS PARA ABRIRCE
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 16, 2012
5 Suggested Answers
SOURCE: Lens error M425-12 (7f80) appears/ camera shuts down
yea.. i also got sand in my camera and i have thje same problem... there is no help anywhere on the internet for us :(
Posted on Jul 20, 2008
SOURCE: code:m440-33
I dont think this was the ebst way to fix this error code but i finally got mad and threw it up and let it hit the ground and it started working again. I figured if i had to buy a new one i would try this first and it worked
Posted on Nov 26, 2008
  • 11967 Answers
SOURCE: when i tourn on my camera it says that is a error
Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Posted on Jan 29, 2010
lock123
  • 6831 Answers
SOURCE: when i turn on my
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
I was using my camera on the beach earlier and im not sure if sand got it in but i was using it and a minute later i turn it off and then try to turn it back on but a black screen appears and tells me...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. Pay particular attention inspecting around the gaps of the circumference of the lens barrel for any sand particles. A single grain stuck in those narrow gaps can jam the barrel.
Nov 23, 2010 | Canon PowerShot SD1100 IS Digital Camera
Camera will not switch on/off properly, and "E18" appears on the screen
"E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 06, 2010 | Canon PowerShot A95 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
LENS ERROR ON KEEPS COMMING UP.HOW DO YOU RESTART IT?! WHY TELL YOU TO RESTART IT WHEN YOU DONT KNOW HOW TOO?IVE LOOKED EVERYWHERE
Lens errors are fairly common. As you've found, the recommendation to restart (turning the camera off and then back on again) usually does not work. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 14, 2010 | Canon PowerShot A480 Digital Camera
Lens error, restart camera
This error occured when lens is prevented from properly extending or retracting. When pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed due External shock or liquid, sand & dirt etc. enters the camera.
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting.
2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera OFF and then ON again then your device need to be repaired.
Have a nice day Rating the solution is highly appreciated.
Mar 06, 2010 | Canon PowerShot G9 Digital Camera
E18 code
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 26, 2009 | Canon PowerShot A80 Digital Camera
Lens eror
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 15, 2009 | Canon PowerShot A420 Digital Camera
When i turn on camera the screen tells me to turn it off and on again and the lens wont open
Jul 10, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Lens error
May 17, 2009 | Canon IXY 1000 Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
HP Photosmart M447 Digital Camera Logo
162 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
