CPU = 1 processors detected. Cores per processor = 2 Genuine Intel(R) CPU T2060@60GHZ 2639 system RAM passed. 1024k Cache SRAM passed. system BIOS shadowed video BIOS shadowed
  • 629 Answers
If you are referring to the detected processor in the task manager, open task manager and click the VIEW menu, then select One Graph Per Processor. Another thing to do is to go to START, then click RUN, type MSCONFIG and click OK. Once you have the MS CONFIG window up, click the BOOT tab, click ADVANCED OPIONS. From there, select/check the Number Of Processors box, then select 2. Click OK, then APPLY/OK. Restart the computer and confirm if that resolved the issue. Hope this works. Feel free to rate how useful the info is.
Posted on Nov 15, 2010
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
Cant find upgrade info on cpu for this
http://h10025.www1.hp.com/ewfrf/wc/product?cc=uk&lc=en&product=4320950
Product information> Product specifications> HP G72-B02SA Notebook PC Product Specifications>
Intel Pentium P6100 CPU (Processor),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#.22Arrandale.22_.2832_nm.29
Uses the Socket G1 processor socket,
http://en.wikipedia.org/wiki/Socket_G1
"The current CPUs to use this package are the Core i7-6x0M series, the Core i5-4x0M series, the Core i5-5x0M series, the Core i3-3x0M series, and finally the Pentium P6x00 series and Celeron P4x00 series which were released on March 28, 2010. However, not all of these are available for Socket G1, as some of them are only available in a BGA package."
http://www.cpu-world.com/Sockets/Socket%20G1%20%28rPGA988A%29.html
Motherboard Chipset not stated on HP Support.
I forgot. This is HP UK Support.
People in the UK are the best, but the UK support information for anything -> BITES!
The Product Number is XF133EA.
Let's try it that way,
https://h10057.www1.hp.com/ecomcat/hpcatalog/specs/provisioner/05/XF133EA.htm
Processor subheading -
Chipset: Intel HM55 chipset
http://en.wikipedia.org/wiki/List_of_intel_chipsets#LGA_1156
LGA 1156 processor socket,
http://en.wikipedia.org/wiki/LGA_1156
LGA 1156 processor support list,
http://en.wikipedia.org/wiki/LGA_1156#Supported_processors
I'll just go back to the G1 processor socket CPU support list.
(CPU = Processor)
Much easier(?)
There is no Front Side Bus. (FSB)
These processors use QPI.
Quick Path Interconnect,
http://en.wikipedia.org/wiki/QPI
Therefore look at the Ram Memory support, and the Voltage range, used by the Intel Pentium P6100; to compare to processors that may be supported; and add to that the processor MUST use a Socket G1 processor socket.
1) Ram Memory support
2) Voltage Range
3) Socket G1 processor socket
Pentium P6100 ->
Supports DDR3 Sdram ram memory at 1066MegaHertz.
It is the 1066MHz to keep in mind here.
Voltage range; .0775 to 1.4 Volts (DC)
Okay, now compare to list of supported Processors, on the CPU-World / Socket G1 article,
"Socket G1, or rPGA988A, is a socket for first generation of Nehalem-based mobile microprocessors.
Me: ->FIRST generation of NEHALEM based MOBILE processors.
NOTE* ->
The socket was introduced in September 2009 along with the ->first three Core i7-branded mobile CPUs, and eventually it was used for Core i5, Core i3, mobile Pentium and mobile Celeron families.
Me: In order of technology, or crudely can be stated as, "which is better", the order is;
Intel Celeron
Intel Pentium
Intel Core i3
Intel Core i5
,plus the first three Intel Core i7 processors, that used the Socket G1 processor socket.
NOTE*->
The rPGA988A works with dual- and quad-core chips, built on 45nm and 32nm technologies, and operating at frequencies up to 2.8 GHz.
Me:-> Core technology based on 32NanoMeter, or 45nm.
Up To a 2.8GigaHertz frequency rate. ('Speed')
NOTE*->
The socket supports DDR3 memory with data rates up to 1333 Mhz, and Direct Media Interface. Socket G1 was superceded by socket G2."
Me: Stick with 1066MHz ram memory, and Intel processors that support it.
Moving on..........
Processors supported, going from Core i7 down.
[NOTE* Dealing with a laptop/netbook processor is different than a desktop processor.
You are looking for 'processing power', but also power saving features.
Power saving as in how much power the processor will use.
Mobile processor = Laptop/Netbook processor.
The less power it uses, the better for a Laptop/Netbook.
The battery will last longer.
Therefore it really is up to you.
Balance of processor 'power', and saving battery power ]
Core i7 - 6x0M
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Arrandale.22_.2832_nm.29
Only 2 use the G1 CPU socket.
Intel Core i7- 620M, and Intel Core i7 - 640M
The rest use the BGA surface mount that has 1288 solder balls.
Explained at end of solution, about the BGA surface mount.
Notice they are Arrandale Core. Also the Arrandale Core is based on the 32nm architecture.
Notice they support DDR3 Sdram that is 1066MHz.
Notice ALSO that it is -> TWO DDR3 Sdram ram memory modules.
THAT, is what you want.
NOT an Intel Core i processor that needs THREE ram memory modules, ('Stick'), in order to operate.
Long dissertation, will include detailed info at end of solution.
You actually need to know the old technology, and compare to the newer Intel Core i technology, to fully understand.
CPU World processor support list also includes Intel Core i7, model 920XM, and Intel Core i7, model 940XM processors,
http://en.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Clarksfield.22_.2845_nm.29
To me this = No.
DDR3 Sdram ram memory, but 1333MHz frequency rate. ('Speed')
Also voltage range is .0650 to 1.4 Volts.
MAY work, MAY NOT.
BIOS may recognize the processor, and make changes accordingly.
Then again it may not.
BIOS upgrade? I'll pass. Too easy to scre-w up, and also miscommunicate proper procedure.
Stopping for a second;
The Core i technology will 'slap a Pentium around'
It's like comparing the 'grocery getter car' to a fuel dragster.
Core i3 and Core i5 technology has less 'processor power', than a comparable Core i7, but the Core i3, and Core i5 were also designed to use less power. Therefore (Supposedly) more battery life.
The Intel Pentium P6100 is a dual core processor. Two processor cores.
http://ark.intel.com/products/50175
But the Core i7 is essentially a quad core processor.
Four processor cores.
This is because it uses the old HT technology.
Hypertransport Technology.
Two REAL processor cores, and if it is needed Two VIRTUAL processor cores.
Intel Core i7, model 620M; for an example,
http://ark.intel.com/products/43560/Intel-Core-i7-620M-Processor-4M-Cache-2_66-GHz
2.0GHz maximum frequency rate for the Intel Pentium P6100.
2.26GHz for the Intel Core i7-620M
Nothing to write home to Mom about, as far as using 2 processor cores.
But when the 2 virtual processor cores of the i7 kick in, that's when the Pentium P6100 would get lost in the dust.
Instead of having two processor cores operating at 2.0GigaHertz, (Pentium P6100), you have FOUR processor cores operating at 2.66GHz.
Crude example?
Two men digging a ditch. Take them out, and replace with four men.
Which scenario will get the job done faster?
HOWEVER, surfing the internet? Watching a video?
Only 1 or 2 cores are going to kick in.
Playing an intensive game, or running an intensive program?
THEN all 4 cores kick in, and kick sum boot-y.
Lot of prattle I posted. Hope you can make some sense of it.
Ha! I just found this. Here is the 'definitive' CPU Support list.
It is listed in the Compaq Presario CQ72 Notebook PC and HP G72 Notebook PC - Maintenance and Service Guide. (Service Manual, really),
http://h10032.www1.hp.com/ctg/Manual/c02641840.pdf
Page 11:
"Intel Core i7-620M
Intel Core i5-540M
Intel Core i5-520M
Intel Core i5-430M
Intel Core i3-350M
,and Intel Core i3-330M"
http://en.wikipedia.org/wiki/List_of_Intel_Core_i5_microprocessors#Nehalem_microarchitecture_2
http://en.wikipedia.org/wiki/List_of_Intel_Core_i3_microprocessors#Nehalem_microarchitecture_2
'Straight from the horses mouth'
Now we know.
http://www.hardwaresecrets.com/printpage/535
http://www.hardwaresecrets.com/article/Inside-Intel-Nehalem-Microarchitecture/535
For additional questions please post in a Comment
Regards,
joecoolvette
Feb 22, 2013 | HP Computers & Internet
E-E61 media test failure check cable pxe-mof exiting pxe rom. operating system not found. how do i find it
Hard drive lost communications with motherboard. Remove it and reseat it. Check BIOS if it sees the HD.
Disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
Oct 05, 2012 | Acer Aspire 9410z Laptop Computer 17"
I want to update my bios
Oh?
Kvpsy,
The information tells me;
1) Operating System: Windows XP Pro with Service Pack 3 (SP/3)
2) Processor: (CPU) Intel Pentium 4, 3.06GHz,
(Or also stated as 3.066MegaHertz) {3.066MHz}
Uses an LGA775 processor socket.
Front Side Bus = 133MHz.
(Intel processors are 'Quad Pumped'. 133MHz is the Internal Clock. 533MHz is the External Clock.
4 x 133 = 532. Number is rounded up to 533)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
Scroll down.
Prescott Core, 90nm architecture.
Pentium 4 HT model 524.
sSpec number on top of the Processor, (Heatsink removed), is either
SL8ZZ, or SL9CA
3) Motherboard manufacturer name, and model number:
Intel D101GGC
Version AAD357
3) Motherboard chipset:
ATI Radeon Xpress RC410 = Northbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
IXP450/SB450 = Southbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Southbridges_2
4) GPU: (Graphics Processing Unit, or slang = graphics chipset)
Built into the motherboard chipset; ATI Radeon 200 series with 256MB's of graphics ram memory.
(? Really? I would think more like 64MB for Integrated Graphics.
Are you running a graphics card, in the PCI-Express slot on the motherboard? Got one in one of the PCI slots?)
5) Ram Memory:
2 Ram memory slots
DDR Sdram at 400MegaHertz. Also known as PC3200.
Maximum TOTAL amount is 2048MB. (2GB)
Amount of ram memory that installed now, 1024MegaByte. (Or also stated as 1GigaByte)
960MB is what shows.
(64MB's of ram memory is being borrowed)
32MB DRAM modules. Memory module/s ('Stick') use 5 Volts (DC)
60nanosecond to 70ns, Cas Latency of 3. (CL3)
6) Harddrive:
IDE
Western Digital WD1600AABS
150GB
7) Optical Drive:
IDE (EIDE really)
Manufacturer = LG Electronics
Model number = GH22NP21
DVD burner drive
8) C-Media CMI8738 audio (Sound) chipset
9) RTL 8139 Ethernet chipset
10) Basic Input/Output System (BIOS) manufacturer = Phoenix/Award.
Version = 6.00PG
Release date = 04/20/2006
BIOS String ID = GC11010N.86A.0311.2006.0420.1525
NOW, the message you received is -
SUGGESTION: Are you looking for a BIOS upgrade?
System BIOS is more than 2 years old. (WELL NO KIDDING!!)
Video BIOS is more than 2 years old. (Yeah? AND?)
A) AS SOON as you purchase a motherboard, the BIOS program is ALREADY out of date.
BIOS upgrades are made about 2 weeks, after the motherboard hits the market.
TWO WEEKS!!
What does this mean?
It means LEAVE IT ALONE.
If everything is working OK, DO NOT perform a BIOS upgrade.
Why?
Because for;
1) IF, the power goes out to your house/business, when you are downloading, the BIOS upgrade WILL NOT be completed.
What does that mean?
Take the motherboard out of your computer, and use it for a Frisbee.
2) IF, the BIOS upgrade is too new, and/or NOT compatible, AND if you do not save the old BIOS version, take the motherboard out of your computer, and use it for a Frisbee.
IS there a cure for ruining the BIOS program in your BIOS chipset, on your motherboard, and downloading, and installing the original one?
SURE!
Take it to a PRO, who will download the ORIGINAL BIOS, to a Floppy Disk, (Or disks), using an internal Floppy Disk drive, connected with a floppy disk ribbon cable, to your floppy drive connection on your motherboard, and put it on your motherboard.
MAYBE.
(Not shouting. Illustrating a point)
OR, if the BIOS chipset is removable, (It is soldered on the motherboard), perhaps another BIOS chipset is available, for a PRO to solder the good one back on the motherboard.
You HAVE been advised.
BIOS upgrade download page,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021749.htm
Motherboard Manual,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Regards,
joecoolvette
Jun 16, 2012 | Intel Computers & Internet
My notebook ACER ASPIRE 4741g-372g50mnkk can't go to BIOS set up (when i press F2) If I Press FN+Esc it will show that Phoenix SecureCore(tm) NB Copyright ..... All Rights .... V1.18 CPU =...
Your BIOS is hosed. This could mean that your BIOS chip has simply failed, or that an attempt to
update BIOS failed, or that a pernicious virus has erased part of your BIOS EPROM chip.
Fix: replace BIOS chip - its a physical EPROM chip on the motherboard.
Why this is nearly impossible for the experienced home electronics buff: modern PC boards,
especially those used in laptops/notebooks/pad computers, where space is tight, are
wave-soldered, and virtually impossible to work on - for even the experienced hobbyist.
Your only hope: the BIOS chip is SOCKETED, and can therefore be unplugged (using, of
course, proper anti-static techniques), and replaced. But IC chips sockets are virtually unknown
in laptop/notebook/pad/cell phone construction.
Sep 03, 2011 | Computers & Internet
CPU=1 Processors Detected, Cores per Processor =2 Intel (R) Corel (TM) 2 Duo CPU T5450 @1.66GHz 1015M System RAM Passed 2048 KB L2 Cache System BIOS Shadowed Video BIOS Shadowed ATAPI CD-ROM:...
if that is all you are getting a the system start, there is a good chance the hard disk drive may have failed. Try reseating the drive then F2 to BIOS, reset defaults and see if the system will boot. If HDD isn't detected in the bios, it has likely failed.
Jul 01, 2011 | Computers & Internet
Hello sir, the system zone-2 temp., always keeps flashing in red.
It is a motherboard problem. But you can disable that alarm from the BIOS. I would simply raise the upper threshold in zone two from 56 to 60 if I were you. If it still flashes red put it back to 56 and disable it.
Apr 26, 2009 | Intel D865GBF Motherboard
UpGrade
download cpuz it will tell your specs
Oct 18, 2008 | E-Machines eMachines Desktop PC
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
1,513 people viewed this question
David Payne
David Payne
