Question about Sanyo DWM-2500 System
How do i set the am/fm radio stations - Sanyo DWM-2500 System
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Nov 10, 2007 | Aiwa CR-LD120 AM/FM Radio
My radio only works for a short distance then goes staticky, also can't set the time
the operator guide in the glove box , covers time set.
all radios do that.
and if not normal, the antenna is broken or fell off the rear of radio.
if got static switch to FM ,
many AM stations, broadcase to am and fm same content.
so use FM. its static free. (by design) but does fade sooner.
you can in fact hear AM station 12,000 miles away it night
called super stations, 50,000 watt stations. ive done this many time.
did you try another car, in same spot , and same station?
are you in under ground parking?
Aug 13, 2013 | Jeep Liberty Cars & Trucks
In my settings there is no fm transmitter selection available
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
It will scan but not hold a station
Hi
i think the fm settings is not lock in to fm scanner! or program the fm station then lock it in ti memory
Thanks!
Jun 05, 2009 | Coby CX-61 FM Radio
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Nokia 5220 expressmusic FM radio always says off
I have the same problem and don't see a way to set the frequency of the stations if you can't set the radio to on...............
Nov 07, 2008 | Nokia 5220 XpressMusic Cellular Phone
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Sanyo DWM-2500 System Logo
22 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
