Question about Car Audio & Video
How to install eclipse e3309cmt car radio - Car Audio & Video
Radio install
Go to a pro or radiostore for help. Ur library sec 600 has info. Utube
Aug 14, 2016 | Cars & Trucks
How to reset eclipse avn51d?
www.eclipse-web.com/us
Jul 13, 2014 | Car Audio & Video
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
Mitsubishi eclipse radio code
take the registration and a picture ID to a Mitsubishi dealer and they can give you the code and show you the procedure to install the code.
Feb 13, 2010 | 2000 Mitsubishi Eclipse
How do you set the time for an eclipse 3309 cmt
to set the clock on a eclipse e3309cmt stereo :
press and hold the "clock/display" button, then number 1 or 2 for the hours 1 = up 2= down.
the 3 or 4 for the minutes 3=up 4=down.
Jun 17, 2009 | Car Audio & Video
My Eclipse Model: eclipse DVD/CD/AV/NAVI system UCN884
ELECTRORAMA ELECTRONICE
HAVE THE CD TO BOOT UP YOUR ECLIPSE 884 TO WORK
TRINIDAD.. PH # 662-6387...DAVID & DANIEL...
Nov 22, 2008 | Eclipse (AVN7000) Car DVD Player
Eclipse CD8445 Clock Problems
First off who installed the radio?
If you or a friend did you ned to make sure that 12+ always is supplied to the radio and is hooked to the appropriate wire on the radio. If it does have 12+ always and it is hooked up correctly a replacement of the radio is in order, however I bet the wireing to the radio is crossed or the radio itself is uncorrectly installed.
The reason is the accessory and 12+ always wire has been crossed or was never there to begin with.
Nov 17, 2008 | Eclipse CD8445 CD/MP3/WMA Receiver
The CD/clock screen has stopped working...
Go to Best buy- have a new radio installed
Aug 15, 2008 | 2001 Mitsubishi Eclipse
Eclipse CD8445
make sure that the additional box is hooked up to the cable, or else the display will not function
Oct 16, 2006 | Eclipse CD8445 CD/MP3/WMA Receiver
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
