Question about Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red
I have the s9-hd motorokr and its stuck on the green light, the light wont turn off at all, how do i get it to turn it off and get it to work again, email me please at rglennj@gmail.com, thank you...
Motorola s9 headset wont turn on
Mine is doing the exact same thing. Does anyone know what the problem is? If so, what is the fix.
Apr 27, 2012 | Motorola Mobility MOTOROKR S9 Wireless...
How do I put the motorola s9 hd wireless headset in pairing mode for a iPhone 3G ?
Starting with your headset turned off, press and hold the power button for some 6 seconds, until the indicator light flashes alternately in blue and red. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a while the S9 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros). The indicator light will flash some times and enter stand-by mode.
Hope it works for you.
Regards, Carlos
Sep 01, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
Sep 20, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Trying to connect motorola s9hd to the laptop
assuming you have bluetooth installed on your laptop,
1) you have to disable the bluetooth pairing of your s9 with another device that you may have paired with it earlier - like a mobile phone. disconnect previously paired devices first.
2) turn on the bluetooth feature on your pc and ask it to "search" for devices. assuming your s9 is on standby, your pc should be able to "locate" and pair with it assuming the s9 is within an arms length distance from the computer.
3) make sure that the s9 is completely charged to eliminate that power issues as well
Apr 07, 2009 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Motorola motorokr doesn't work
The mic stopped working on my S9 after 2 weeks and removing the BT device and repairing did the trick...try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). .
Mar 27, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola s9 mic does not work
try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). Mic stopped working after 2 weeks and removing the BT device and repairing did the trick.
Mar 11, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorokr S9-HD headphones does not pplay music with Fusic phone
On your smartphone, you need to enable the bluetooth wireless headset settings. There may be a seperate setting on your bluetooth options for enable wireless headset and enable wireless handsfree.
You may also want to check and make sure the volume is turned up all the way on the smartphone media player and on the headset.
Jan 12, 2009 | Cell Phones
Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
149 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
