Question about Taylor Kitchen Scale – (6 lb) ()
I just bought I digital kitchen scale (Model number 3831 BL) I can turn it on/off and change it from ounces to grams but not matter what I put onto the scale it never changes off of 0 (zero). Please help!
  • 4 Answers
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
Sorry - no solution - but I am having the exact same problem with a new scale - same model. Did you ever figure out how to make this work? Thnaks!
Posted on Apr 12, 2011
What 3 tools should I use to measure 5 grams of macaroni , 10 ml of milk and 3 cm of butter?
To measure the macaroni, you are measuring mass or weight, so you would need a scale.
To measure the milk, you are measuring volume, so you would need a measuring glass or a set of measuring spoons.
To measure the butter, you are measuring distance, so you would need a ruler.
I hope this helps.
Let me know if you have any questions.
Good luck.
Paul
Sep 08, 2015 | Home
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Change lb to gram
Number of grams multiplied by .0022 = lbs,
Dec 10, 2014 | Salter 2001 electronic kitchen scale
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Sep 24, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Feb 08, 2010 | Health & Beauty
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Taylor Kitchen Scale – (6 lb) () Logo
577 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
reici_42
Level 1 Expert
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
