Question about Microsoft MN-700 Wireless Router (p5308j)
How to access this unit? i want to change the password
  • Microsoft Master
  • 7,733 Answers
To change the Base Station password, follow these steps:
  1. In the left pane of the Base Station Management tool, point to Management, and then click Change Password.
  2. On the Change Password page, type the Current Password, type the New Password, and then confirm the new password by retyping it in the Retype new password box.
  3. Click the Apply button to save the changes.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 15, 2010
What is the username and password for the brighthouse ubee
You are able to access some of the modem/router settings using the credentials:
User Name - "user"
Password - "user"
Without the quotes, of course. This will not give you complete access, however, it will allow you to modify a fair amount (not in my opinion) of settings and view various modem/gateway information pages.
Unfortunately, Brighthouse (BHN) is on their game, when it comes to locking certain features/settings from being changed by the consumer. Time Warner Cable (TWC) sold select areas to BHN some time ago. TWC is a bit more open to user changes.
For example, TWC and BHN both supply the modem/router Ubee DDW3611. TWC's supplied unit's configuration can be accessed by the customer through the 'User' account and the 'Admin' account. BHN, on the other hand, only allows the customer to access the configuration through the 'User' account-which limits the available configuration options.
TWC units may be accessed through the 'Admin' account using the following credentials:
User Name - Last 8 characters of the Ubee Modem MAC Address
Password - c0nf1gur3m3
For example: If your Ubee Modem MAC Address is "1C:6D:CB:14:D6:4A"
Your 'Admin' credentials would be:
User Name - CB14D64A
It is very unlikely that the aforementioned credentials will work to log in to the 'Admin' account for BHN supplied units. But hey, its worth a shot. Right?
Hope this helps.
-James.
Aug 12, 2013 | Computers & Internet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Password
1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Apr 09, 2012 | Apple AirPort Express Base Station with...
How to change my password?
It is pretty difficult to help you without knowing the BRAND and MODEL of your router, BUT here are generic items that should be addressed.
There are a couple of areas for passwords, the access to the programming of the router, as well as the wireless access....
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Jul 11, 2011 | Computers & Internet
How to set up password on my wireless router ?
The answer to this depends on WHICH password...... Router access, or wireless access. Run the install wizard from Edimax....but here are the highlights of what should be set:
Wireless Router
It is usually easiest to run the install wizard from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below.
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
Apr 24, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Cant get my password to work or any thing eles
If you are actually talking about a router, then press the reset and set up the unit again. Generic directions below.
If you have an access issue, try password reset options from the host entity.
Wireless Router
Things to set:
Mar 22, 2011 | Computers & Internet
I need to get a password so that others will not be able to use it
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below. To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
Mar 11, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How do i access the setup page what is the 192.168?????
192.168.1.1 or 192.168.1.0
username is admin
password is either the word password or admin
Mar 06, 2011 | Zoom 5241 Modem
Wireless access point Pda 1360
To perform a reset, please follow the steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Note: Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults including IP address, username and password.
May 29, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I forgot my password for belkin f5d7231-4
Do you mean the password for the wireless network or the password for the router. If you don't know the wireless network key or the password then you will need to access the router set up and you will find the wireless password there. If you don't know the password to access the router then you will need to reset the router and reconfigure the router. Click Here for step by step solutions
Nov 16, 2009 | Belkin (F5D7230-4) Router (587009)
Microsoft MN-700 Wireless Router (p5308j) Logo
368 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
