Question about Jensen Q2049J 20" TV
My remote will not work What can i do. How can i tell if the sensor is bad?
    Top Expert:
  • Jensen Master
  • 74,383 Answers
Hello
You can check your reote hansets condition, if you have a mobile phone with camera option. Put the phone onto camera mode, and place your Tvs remote control's front side towrds the lens of the mobile, about a feet away from it, and push remote switches one by one. You can see an image of infrared light comes from it for each button push. If it is there, you can make sure that your remote handset iw working. If not the trouble is with your remote hanset, not at the TV.
If remote handset have infrared emission, as described earlier, and you cannot control the TV with it, the remote sensor inside your TV is faulty. Ok
Posted on Nov 15, 2010
My heater suddenly stopped working with my remote. Heater says remote no demand
if no demand maybe bad temp sensor disconnect heater connect firemans switch or take it out of t stat if runs on its own bad temp sensor for system if same error bad temp sensor on heater replace
Jul 14, 2015 | Raypak Pool & Spa
Toshiba 43" 43H70 Projection TV - Remote Sensor not working
Here is your manual
Someone else with same problem
Seems like they you may have sensor problem, remove board and check solder connections and/or replace IR sensor bad pic below of toshiba sensor board below.
7151e29.jpg It should be hidden behind the smokey plastic cover in the right corner of set,
Dec 30, 2007 | Toshiba 43H70 43" Rear Projection...
Rca rc1113123 00
If you look at the remote through a video recorder likable maybe a smartphone. You will be able to see the infrared light up. Infrared only shows up on photo or video.
Dec 06, 2013 | RCA Televison & Video
Vizio remote suddenly not working
The first thing is to test the remote: some digital cameras will if on and the remote pointed at them react on screen to the signal when buttons are pressed.
Also almost every tv shop or Radio Shack has a remote tester--point the remote at it and push any button and a strip or indicator on the tester will light up----tells you if remote is sending a signal or not.
If remote tests good---remote infrared receiver is likely bad in the set or something near it is bad.
Mar 19, 2012 | Televison & Video
Tv shuts off by itself
change ur remote batteries, if no work still remove batteries see if help
tv may have a bad remote sensor, the sensor that tell tv go on, off, change chanel , change volume.... and so on.
or ur tv motherboard
or may be try factory reset ur tv if tv program bugged.
Jan 28, 2012 | Televison & Video
Remote control No work
Try another remote control, if it is also not working that means remote sensor in tv got bad and become unable to receive remote signals, replace remote sensor in tv.
If other remote works then replace batteries in bad/ suspected remote and check.
Let me know model and brand of your tv if you have additional question.
Thanks.
Dec 26, 2010 | Samsung Televison & Video
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
Aug 11, 2010 | RCA Universal Remote Control
How can i tell if the remote sensor in tv is bad
If you the new maufacturer remote does not work then you need to find out if the remote receiver is getting 5vdc feeding it. You will need a scope to see the digital signal from the remote receiver board.
You can try new board from here:
www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 21, 2010 | Televison & Video
My remote is working but its not working with tv
It is possible that the remote IR sensor is bad, this does happen on a few of these. The repair should not be very expensive if it is out of warranty, it is located on a small pc board that can be replaced fairly inexpensively. i would say the repair may cost around 100.00 from a shop.
To speed up your repair, tell the shop that you checked your remote, i am assuming you aimed the remote at a cell phone camera or somthing like this, tell them how you checked the remote. They will then know for sure the remote is good. This may speed up repair they may come out to your house with a board ready so you will not have to wait for a second trip.
Oct 10, 2009 | Philips 47 in. LCD HDTV
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Jensen Q2049J 20" TV Logo
61 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
