Question about Pentair Pool & Spa
My pentair mini max display is indicating a "LO" .
  • 310 Answers
The pentair mini-max only displays LO when the water temperature is at or below 58 degrees F.
The heater is set to not fire at this temperature due to the condensation that can occur.
If the water is above this temperature and you are still getting this code, the temp sensor is installed incorrectly or is just bad.
If you need futher advise, e-mail me here.
adamh@newconceptchem.com
Posted on Nov 15, 2010
Why is there no display on my pentair mini max nt?
is ther power going to it if so check power supply or main power conversion board
Aug 22, 2014 | Pentair Minimax NT Heater
Mini max my power light comes on but my pressure sw does not light up
Try cleaning the filter, or check the water flow. It's sensing not enough water flow through your system.
May 14, 2014 | Pentair Minimax NT Heater
Pentair MasterTemp 250 Natural Gas Heater with "Service System" issue
this heater will display 2 red light related problem 1-service the system mean you need to clean you filter, and service the heater mean it may be a problem with the heater this 2 you will be able to see it in key pad control the heater ,now reset the board and see what happens (CUT THE POWER ON/OFF UNCE )
Jun 09, 2013 | Pentair Pool & Spa
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Air Flow Fault, E04 and E05 Errors, all are ingniter related?
Is it the digital user interface? Often when you are receiving multiple error codes, its the control board that is bad. This is not as common in Mini-maxes and it's an expensive fix but it might be what's wrong. Most heater problems, however, don't have anything to do with the heater. Make sure your flow is good. Clean all baskets (skimmer and pump) and backwash (D.E. or Sand filters) or clean (cartridge filter) your filter.
www.CPO2go.com
Nov 21, 2010 | Pentair Minimax NT Heater
Digital display shows LO what should i do
LO is a limit string open. This is what I refer to as a saftey circut. It will peobally be a dirty filter or a plugged up basket. The heater need enough water flow to run or it will overheat and cause damage to the heater. Without enough flow the saftey circut shuts the heater down before this can occur. If it is more than this it is probally time to get a repairman involved. Good luck and remember this is a box full of fire that runs on high voltage.
Mar 05, 2010 | Pentair Minimax NT Heater
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
No display lights
Make sure you have 24 volts coming from the transformer...Alot cheaper part.
Jun 01, 2009 | Pentair Minimax NT Heater
Pool & Spa Logo
79 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
