Question about Garden
I purchased a Brinks EZ Preset Timer. I followed the directions and can not get my light to turn off in the 2 hour time that I set it at. If I have the timer on as soon as I plug in the light it turns on and never shut off. Am I not suppose to turn the timer on? I tried letting it sit there in the dark without turning on the timer and it still did not start.
I have the same problem with these timers! I thought that you could turn it on by pushing the "on" button, set how many hours you want it on for and that's it. It doesn't go on unless I unplug it and use my thumb to cover up the light sensor. Then I can set the hours and it will go off after say, 6 hours. I wish there was a solution that didn't involve unplugging it each day.
Posted on Dec 14, 2010
I have the 'Brinks EZ timer number 42 1009 and I can not get it to turn on a a specific time. it goes on thru the night
Timer is not identified. Add a comment and describe timer in detail.
Only resources appearing on internet for that timer are links to fixya. That means there is no information available.
However you can add comment and describe timer in detail and I can locate something similar, and possibly help.
Or buy identical new timer at Walmart, and return defect timer in new package for refund
Or copy following links to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://www.hamptonproducts.com/contact-us.php
Gene
h
Aug 13, 2013 | Hampton Technologies Brinks Timer
Setting brinks ez 42-1006 timer
1) Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
2) Use link above to Experiment with features
Dec 14, 2012 | Hampton Technologies Brinks Timer
Help me work this thing please?
Brinks analog plug-in-outlet timer??
Copy following link for instructions how to set timer by experimenting with features:
Nov 02, 2012 | Hampton Technologies Brinks Timer
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
November 2010 I purchased a Brinks 42-1050 Outdoor timer for Christmas lights. Recently I tried to use if for a temporary pet light. Problem, the clock does not keep time. Can this clock be repaired. I...
This timer cannot be repaired.
Solution 1:
Timer has 1 year limited warranty from hampton products.
Warranty might apply.
Aug 2011: open following links for hampton:
http://www.hamptonproducts.com/customer-care.php
Solution 2:
Buy another identical timer from Walmat etc.
Return defect timer in new package.
Aug 19, 2011 | Hampton Technologies Brinks Timer
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 29, 2011 | Hampton Technologies Brinks Timer
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 24, 2010 | Hampton Technologies Brinks Timer
Garden Logo
357 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
