Question about SpeakerCraft MZC-66 Amplifier
I do not get any audio -unit is 3 yrs old-I can control my tv but no audio from any of my outputs-amplifier?
    New Friend:
  • 30 Answers
I can fix this so it never happens again. Please contact me,
http://calgary.kijiji.ca/c-buy-and-sell-electronics-Speaker-Craft-MZC-and-BB-Series-Amplifiers-Repair-Service-W0QQAdIdZ229607818
Posted on Mar 10, 2011
  • The Seeker May 12, 2011
    This is a known problem with this model. Please see our website for help.
    http://calgary.kijiji.ca/c-buy-and-sell-...
    Problem Solver:
  • 8 Answers
You are connecting everything correctly and it just has no output on any channel? I would say check and re-check all the wiring and if you still get no output despite giving it an input signal then the unit needs to be opened up and troubleshot. Without anymore info i can't offer you anymore help over the internet. You might wanna open it up and give the circuitry inside a good visual inspection. You might find open fuses, circuit board problems or toasted components, and be able to attempt a repair yourself.
Posted on Nov 15, 2010
How to fix the sound on the Bose Solo TV system
Contact the authorized service center for Bose. The fault is with its audio output amplifier section circuit. Normally, it will be difficult to get spare parts to this set at local electronic spare part market.
Gopakumar Gopalan Google
Jun 09, 2015 | Bose Solo TV sound system - Black
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
Proscan PA31122 TV audio amp
my regservo need to active plz help me for activation code
Dec 29, 2013 | Proscan Used Original PS31122 SIMPLE...
How do i connect my amp to my vizio tv there are right and left outputs on tv but only one input on back off amp
Typically you need an preamplifier between your tv and amplifier. you run one optical cable (or coax ) cable from you tv audio output to the preamplifier then you run audio rca cables from preamp outputs to amp inputs (2 for stereo 5 or 7 for surround). the preamp decodes audio and controls volume and surround modes.
If you have a cable box and need just simple setup for watching tv just run rca cables from your cable box audio outs to your amp inputs. you then program your cable remote control to control volume.
Oct 29, 2013 | B&K Reference 7250 5-Channel Amplifier
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Apr 26, 2008 | Televison & Video
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
SpeakerCraft MZC-66 Amplifier Logo
137 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
James Oliver
Level 1 Expert
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
