Question about Dewalt DC011 AM/FM Radio
Dewalt radio dc011 does not turn on with a battery or plugged in, but will charges a battery when it is pulled in. I've changed the two AA batteries and checked both fuses (they were both good). when i had it opened up there were no signs of electrical failure no loose wire and all the wire harness seemed to be plugged in. I don't know if this is a common problem with these radios but I'm the second person i know of with the same problems. please help me fix it so i don't have to buy a new radio!
  • 3 more comments
  • phillipsjust Nov 19, 2010
    is there any way to test that switch? if it were that switch would it still charge batteries?
  • phillipsjust Nov 23, 2010
    checked both fuses they were good
    i found the switch that i think your talking about. i blow all the dust out of the radio with a compressor, so it should be clean now. i plugged back in the radio a can hear and fell the switch flipping over but it still doesn't work.
    the radio still charges batteries just fine the radio it self does not work. no signs of sorts anywhere.
  • phillipsjust Nov 27, 2010
    i found the switch and i can hear it click over and fell on the board. the switch looks like it would be working properly and the solder also looks good.
    President:
  • 1,961 Answers
On the power cord input/slot there is a switch there that serves as a selector for battery and AC power in.Whenever the power cord is inserted it triggers the switch and power off the battery If the cords is remove the battery activates.see if this switch is working or replace the switch.good luck!
Posted on Nov 19, 2010
  • Danilo Baraquiel
    Danilo Baraquiel Nov 20, 2010
    The switch is found right on the power cord input.Once the power cord is plug in the charging automatically activates if the power cord is pulled out the switch should engage to off position and activates the batteries.That is a single pole two position switch.One is for charging and the other one is for activating the batteries.The switch might just requires cleaning the contact or the battery terminal is not soldered properly.pull out the switch and examine the contacts by using a continuity test with an multitester . thank you !
You have a short somewhere and/or the charging unit has gone bad. I would replace the charging unit, this component is know to go bad on the DC011. After you replace it your radio will work perfect again.
Posted on Nov 21, 2010
  • Anonymous Nov 21, 2010
    Check fuses inside. Check fuse and connections in plug. If this is a 110v radio there is one on transformer winding
My dewalt radio wont turn on
i have put 2 new batteries but cant get radio 2 work
Mar 28, 2011 | Dewalt DC011 AM/FM Radio
When I shut the radio off the clock and radio memory goes to How do I set the clock and stations so that when I tur it on I have the clock and stations.
Have you inserted 2 x AA batteries in the back where you charge the Dewalt batteries? there is a cover with a black phillips screw, this is where the AA batteries go for the memory clock & radio presets.
Nov 28, 2009 | Dewalt DC011 AM/FM Radio
Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Oct 07, 2009 | Dewalt DC011 AM/FM Radio
Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Aug 06, 2009 | Dewalt DC011 AM/FM Radio
Memoryfunction
Have you installed 2x aa batteries in the back where you charge your battery? if so make sure they have life in them.
Jul 13, 2009 | Dewalt DC011 AM/FM Radio
My used dewalt radio
open up and check fuses
Jan 20, 2009 | Dewalt DC011 AM/FM Radio
Dewalt radio dw911
Have you changed the AA Batteries, this is often the fault, when they are flat they lock the radio out. HHM Dewalt Service
Nov 27, 2007 | Dewalt DC011 AM/FM Radio
Dewalt Radio
dewalt radio works fine on mains
will not work off battery
Aug 13, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
2,074 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
