Question about Scotsman Modular Flaker Ice Machine Water Condensed 395lbs
Scotsman AFE 400 An oil substance is in the ice. My repair man has cleaned two times Still has black . Do not see it on fresh ice but put in a glass after it melts there is black. Mine is a flaker evaporator style.
  • 102 Answers
The seal on your breaker bearing has been compromised it needs to be replaced Its hard to find just the bearing now days They come in a kit which costs close to 800 plus 2 hrs of labor if you do fix it make sure to replace lower bearing and water seal to save than 1000 dollar gear box
Posted on Apr 24, 2014
    Novelist:
  • 112 Answers
You need a more qualified repair man. It sounds as though the bearing or the water seal or both are in need of replacement. Flaked ice machines are high maintenance items. This one may not have had enough maintenance or it is just too late. Look for a Scotsman authorized and trained dealer in your area.
Posted on Jan 04, 2011
  • bcky_may
    bcky_may Jan 24, 2014
    I am looking at a used machine that has this issue. how much could I expect to spend if worse case that bearings & seals had to be replaced? Would thIs this be a machine worth considering or should I pass & keep looking?
  • bcky_may
    The issue is it is putting a oily black substance in the ice. Dirty/maybe oily ice!? What can I expect this to cost to repair materials & labor?
Scottsman ice maker putting black oily substance in the ice. What needs to be checked??
you need to call a refrigeration mechanic because the worm gear seals and transmission needs to be reseald.
Jan 24, 2014 | Scotsman Modular Flaker Ice Machine Water...
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Black flakes
Dose the whole cube have a black tint to it? or dose it have black flakes in it? If all the ice has a solid black tent to it then check your water filter most all filters has charcoal in them when you change one out and apply water to them you need to dump the ice until you get clear ice. Now if it is just black flakes in ice than you need to clean the ice machine with scotsman cleaner nickle safe and scotsman sanitizer follow manufacturers instructions.
Aug 30, 2013 | Scotsman Kitchen Appliances - Others
Do i need to oil the spray pump on my DCe 33 Scotsman ice machine
You can spray lubricant of a silicon base into the rotating part, but you will need to replace the pump.
Apr 27, 2012 | Scotsman DCE33PA1BC 15in Built-in...
I have a scotsman dce 33 it is 10 years old. Service man said it has a leak and is a sealed unit. I would need a whole new sealed unit. Could this be repaired by putting a valve in line, fixing the leak...
What I gather from the technicians remarks are the whole sealed unit and he leaves out the defined area of the leak. Sometimes leaks like this are really difficult to find and repair especially if the ice machine is still in use. To answer your question yes it most likely can be fixed if the leak location is found, fixed, pull another vacuum and recharged with Freon, If you have more questions I will be here to answer them for you, Sea Breeze
Nov 27, 2011 | Scotsman DCE33PA1BC 15in Built-in...
How do i clean my ice maker?
Put your ice maker into the cleaning cycle and run some ice machine cleaner through it.
http://www.appliancepartspros.com/Appliance-Parts/mcn-ice-machine-cleaner-item-number-ap4308815.aspx
Aug 03, 2011 | Scotsman DCE33PA1BC 15in Built-in...
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
The water is running but ice cubes made one at a time and very slow
Hi!!! You have high hard water built up in your evaporator you need too clean the unit.Put a cleaning solution inside..A dirty Evaporator also clean your condensor coil..good luck..
Jan 21, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Refrigerators Logo
320 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
john h
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
