Question about Amana Heating & Cooling
How to clean drain pan and coils inside on amana 80 sse
5 Suggested Answers
  • 85 Answers
SOURCE: my amana 80 sse furnace
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Posted on Dec 11, 2008
tborn6
  • 700 Answers
SOURCE: furnace manual
here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
Posted on Dec 23, 2008
  • 66 Answers
SOURCE: need to clean sensors in amana 80 sse furnace,
The flame sensor is usually on the opposite side of the ignitor, and held down with a 1/4" screw with one wire connected. It has a metal bracket and a piece of porcelin with a metal ,round strip of metal through the inside of it.
Posted on Feb 22, 2010
239gatorac
  • 1711 Answers
SOURCE: Water is draining outside my Amana 80 sse furance, how do i drain the pan
The drain is likely clogged. Take a shop vac to the drain on the exterior of the home. Hopefully this will clear the drain line.
Posted on Aug 05, 2017
Will a wireless thermostat work with my amana command 80 sse furnace?
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
Feb 07, 2018 | Amana Heating & Cooling
Aug 05, 2017 | Amana Heating & Cooling
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
The amana ap095r drain pan gets very dirty and mucky... but after unscrewing the back cover so I could vacuum both coils I dont see a way to clean the drain pan. The pan is part of the entire bottom (one...
Pour some Mr. Clean in the pan and somehow use anything that will fit to clean the pan. Add more water to thepan and allow it to drain.
As far as why they do that...They want to ensure you take it back for service so they can screw you again. I'll bet it only became an issue after the warranty was up.
ASH
Please vote.
Sep 22, 2010 | Amana AP095R Portable Air Conditioner
Where is the drain located in the amana refrigerator that empties the water into the bottom drain pan? ModelTC20E-L Amana frigerator
Good day,
In the freezer compartment, after you remove the rear panel, you will see the cooling (evaporator) coil. There is an aluminum pan directly below the coil. The drain hole would be obvious unless it is iced over, in which case you would need to melt the ice out.
It is connected to the drain hose which you can see by removing the back bottom cover of the machine that houses the compressor. If open and working properly, the hose carries the water to the drain pan which allowsit to evaporate.
If the freezer has an ice maker, it will have to be removed first. In addition any support brackets if they prevent the removal of the rear panel.
Jul 26, 2010 | Amana ARB8057CSL Bottom Freezer...
Need to clean sensors in amana 80 sse furnace, where are they located?
Feb 21, 2010 | Heating & Cooling
Amana AP095R Portable Air Conditioner is dripping water constantly. It didn't use to do this. What's wrong here?
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Aug 17, 2009 | Heating & Cooling
Water is dripping on the floor not going into drip pan at bottom of coils on inside unit could coils be dirty
Yes coils could be dirty, but your drain is clogged. To clean the drain cut the pvc line and blow the drain line out. You can put bleach in the drain pan every 6 months to keep it clean.
Sep 25, 2008 | GE Heating & Cooling
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
506 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
