Question about LG Washing Machines
I have an LG Tromm washer dryer wm3777HW and it shut down today after a signal of PF. I would like to get The wet clothes out but can't unlatch the door. Could it possibly be a fuse? Is there a reset button, and how can I find service in my area?
  • Mikael Wagner Nov 15, 2010
    Thanks unplugging for ten minutes did released the door but still no power. Should probably move towards looking at the fuse box later and then requesting service
  • 5,081 Answers
PF commonly indicates an power failure and it can be because of any part in the machine. We cannot identify which part is damaged unless we manually inspect it by means of using an voltmeter.
Unplug it and wait for ten min , it is an sort of reset. if that did not solve your problem and handy enough in working on the internal parts of your LG tromm let me know i will help you.
If not we have to proceed with an service call.
Posted on Nov 15, 2010
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG TROMM DLG5988S, it doesn't warm up my clothes
your element is defective or a thermal fuse is open, possibly the hi-limit switch is defective
Oct 18, 2009 | LG DLG5988 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hwd1000 washer dryer combo is not moving into the drying cycle
It's time you found out where your filter is, to clean it out thoroughly
Mar 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
147 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
