Question about Cameras
My Samsung Digital Cam has a disc in it but states there's no disc. While recording today I received a "Write Error" message. After that the problem began.
  • Anonymous Jul 01, 2008
    i have the same problem!!!
I have the same problem patti612...Do you know the solution now?
Posted on Jul 01, 2008
My hk 30 player tray flashes (disc error) with every digital audio disc. help
Often times the tray and pickup lift assembly are related and there is a cam alignment. IF you pulled out with force the tray the alignment may have been upset to where the cam is not completing the lift of the Pickup and if not in the right position the laser will not be able to focus. The correct solution is at a Technicians bench where a new belt could be put in, lubrication that is required and some cleaning will be done.
Jan 21, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
When I turn on my camera, in the middle of the screen in a black box it says " DCF full error" what does this mean and how do I get it to go away? I have tried resetting my camera and formatting...
Hello
Thank you for using FIXYA!!!
OK, firstly let me state what exactly the error message you are receiving concludes to:
"The "DCF full error" occurs when you use memory card in your camera which is formatted in another camera. The error is the result of improper formatting of the memory card which leads to incompatibility of the card with the Samsung camera."
Now, i the resolution for this specific problem is to format the memory card in the Samsung camera.
I know you stated that you have already formatted the card, but you did not state if you formatted the card in your camera, or on your computer.
Try the above solution and let me know if the problem still persists.
Please do not hesitate to let me know if you have any further questions.
Kind regards
lock123
May 24, 2011 | Samsung S860 Digital Camera
Getting error message "Din Unlock
That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
May 03, 2011 | Sony RCD-W500C 5-Disc CD Recorder
To whoever can help...I have a Sony, RCD W10. I am receiving 2 error codes when I proceed to record a cd. Error code C13 and C14. Does anyone know what this might mean? Simply frustrated
They are what you call fault codes. A fault code provides a machine-readable identifier that can be used to programmatically identify the error condition and respond as appropriate
Jan 16, 2011 | Audio Players & Recorders
I got the unit(gf-350)home from the store and set it up.at first it worked okay..but only for about two hours.i noticed that the cd's were getting unusually warm after being recorded on.after about two...
It sounds to me you have manufacture defect, you said it worked fine for two hours and then you ran into problems, if there were issues with the cd's they would not have played. I would do yourself a favor and return it for exchange or for a different unit.
Dec 30, 2010 | Teac GF-350 CD Shelf System
"write error, to recover disc, please restart"
what discs are you using as they need to be compatible with the recorder, some discs are one time recording others are + or - and some are rewritable, there is also settings for format that have to be set for the discs.
Nov 26, 2017 | Samsung SC-DX103 DVD Camcorder
I recorded on a disc and now it's not reading it
May i know what type of disc are you using?
Is it DVD+R? DVD-R? DVD+RW? DVD-RW?
You might wanna try to transfer your videos to your computer via USB streaming to check if you can still retrieve your videos.
Jul 22, 2008 | Samsung SCDC163 Camcorder
We have a Canon DC22 camcorder. The disc shows that there is only 4 minutes of recordable time left (DVD-R), but upon review it does not show our recorded video. We know that there was viewable video...
are you doing a finalize on your -r discs? if not finalized won't play in anything but camcorder-dvd can be finalized at any time-you should not lose your footage--rw can sometimes play in players w/out being finalized can also delete scenes and reuse-look for finalize in your playback menus
May 22, 2008 | Canon Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
