Question about Texas Instruments TI-30XA Calculator
I am trying to figure out how to enter negative logs into the TI-30XA. I have a chemistry exam on Tuesday and we need to be able to do problems with the negative log and I can't seem to find any information on it. A sample question is as follows: -log (2 x 10 (neg. 3 exponent)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Use the +- key to the right of the decimal point to enter negative values and to change the sign of an existing value. For your sample:
2 EE +- 3 LOG +- =
Posted on Nov 15, 2010
  • narizacollin Nov 18, 2010
    I was using -log and was getting Error. Finally I entered my numbers first then tried the - log and it worked. Thank you so much!
How to fix error mesage on TI-30Xa. Every time I press LOG an error sign comes up. how do i fix this?
To take the log of a number, enter the number then press the LOG button, then the =. To take the log of a negative number, enter the negative number using the +/- key just to the right of the decimal point. To calculate the negative of a log, calculate the log and then negate it using +/-. To calculate the antilog (inverse logarithm), press 2nd then LOG.
Bear in mind that LOG is the common (base-10) logarithm. For the natural (base-e) logarithm, use the LN key to its right.
Nov 07, 2011 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
How to use antilog?
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Exemple: let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Hope it helps.
Dec 07, 2009 | Texas Instruments TI-30XA Calculator
Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
May 29, 2009 | Texas Instruments TI-83 Plus Calculator
Hoe do you use logarithm on TI-36X SOLAR?
Basically you first have to put your answer into scientific notation by pressing the 3rd key then the 6 key. The screen display should change to one big zero and two small zeros.
I was workinggon the same problem with a -log of a chemistry problem to get pH and I knew the answer because I calculated it on it TI-85, but we are not allowed to use graphing calulators on the exam (:-((() so I had to figure out how to do it on this one!
For example, I had pH =-log(2.828947x10^4)
On the TI-36X you change to scientific notation using the instructions above. Once the three zeros enter on the screen:
[4]
[2nd]
[10^x]
1^-04 should appear on screen, then you multiply by 2.828947
[x]
[2][.][828947]
then your screen will show the answer in scientific notation.
2.828947 in big numbers and in small numbers -04
From there you simply press:
[log]
and your answer will show up as a negative number. Just take the absolute value of that and you have your answer. Took me like 30 minutes the night before a huge chemistry exam to figure that out! Hope it helps someone!
May 09, 2009 | Texas Instruments TI-36 X Solar Calculator
Find the antilog on the TI-83 Plus for finding pH in chemistry problems
I reccently had the same problem, but I have a Ti-84 Plus,and I am disgusted by how poorly this matter is covered by Texas Intruments. Esp. since the solution is rather simple.
The antilog key is [2nd] [log] or the 10^x. On your screen it should apear as 10^( and then you just input the value that you want to find the antilog of.
When used to solve pH problems remember to input the pH value as a negative number, since pH= -log[H+] then [H+]= antilog(-pH).
Hope that helped))))) ^^
May 10, 2008 | Texas Instruments TI-83 Plus Calculator
Chemistry problem
You enter a pH value and change the sign to minus, then hit 2nd LOG which is 10^x. The x value is what you're looking for. To put the answer in scientific notation, press 2nd 5 to do so.
Example:
For a pH = 4.1
-4.1 2nd LOG will return 0.0000794
Hiting 2nd 5 will express it as 7.94 -5, giving you the [H+] concentration.
Apr 22, 2008 | Texas Instruments TI-30XA Calculator
Antilog in chemistry problem
pH is minus (log to base 10) of the hydrogen ion activity of an aqueous solution, or (log to base 10) of (1/hydrogen ion activity)
To get the inverse log, i.e the hydrogen ion activity corresponding to a specified pH, simply enter the pH value and press
2nd
LOG
1/x
Answer 0.001
Texas Instruments TI-30XA Calculator Logo
560 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
