Question about Schlage BE365-CAM BE365CAM619 Satin Nickel Electronic Security Camelot Elec
After installing my lock, i don't have to enter my User code to get the thumbturn to move....my lock never appears to lock
  • 963 Answers
The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
Each time you do this, you toggle between enabled and disabled.
This link will take you to the page for programming information:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt 365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 08, 2011
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
Deadbolt becomes stuck without a lot of force.
This sounds like the fit between the thumbturn and the bolt is compromised. If you pull out the thumbturn, take a look at the flat metal blade that fits into the rectangular or "8" shaped hole in the deadbolt mechanism. I think this has become bent or misshapped somehow. Or maybe the hole has a rough burr on it. You might be able to flatten the blade with a hammer and anvil or maybe dress up the problem with a file. Good luck.
Dec 04, 2012 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
How to unlock nokia 1208
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 15, 2012 | Nokia 1208 Cellular Phone
How to unlock nokia 5230 nuron
Specify which Country Network it locked now?
Because all Network Locked Phones can't be unlocked ,some Network lock cannot be unlocked...Unlock code is best for Unlocking,get the code from here Simpleunlocking.com
and Unlock it from Network Lock...
Nokia 5230 Nuron Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 5230 Nuron mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5230 Nuron mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5230 Nuron without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5230 Nuron.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5230 Nuron would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5230 Nuron mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5230 Nuron
Aug 08, 2011 | Lands Phones
Just want to change 4 digit code to new one
Do this, with the door open:
Remove cover from assembly by sliding cover up and off. You will then see the program button.
A programmed code can be from four (4) to eight (8) digits long.
Up to 2 user codes can be entered.
Excess delay in the programming steps once started will cause unit to beep twice and will require you to restart from step (a).
Programming the first User Code:
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
Programming the second User Code:
a. Press the program button on the interior unit twice.
After programming in just one new code, the existing old code may still work. I suggest that if this is the case, that you program in two codes to make sure that the old one is over-written. You may try programming in the same new code both times if you don't want to have two codes.
Here is a link to the installation and programming instructions that I excerpted the reprogramming instructions from:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For further assistance or warranty information: call 1-800-677-5625 USA & CANADA
or visit, www.kwikset.com
Jul 26, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I have nokia x3 mobile but it is locked in country code please give me tricks
which country's network it locked now?Because all country Network lock cannot be Unlocked ....Only some Network locked Phones can be Unlocked from the Network lock,You can get the Unlock code from here
Wickedunlock and Unlock it... safe and secure...
Nokia X3 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia X3 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia X3 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia X3 without any sim card.
2 - Don't bother as to what is displayed on your Nokia X3.
4 - The Nokia X3 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia X3 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia X3
Jul 24, 2011 | Nokia X3 Cell Phone
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
I just got one of these gave to me from nieghbor lock not real old and in good shape its never seen weather. When you install the battery's it trys to lock then keeps tring to lock for like 30 seconds or...
Here is the link to the installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I think that you may have the door jumper set in the wrong position for the way your door opens (door handing; see page 6 of the instructions).
Dec 03, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
I purchased a new Sentry Safe, Model CSW 4747 yesterday. When I unboxed the safe, the safe was open, the lock handle was down, cyclinders were a little pertruding, and the lock cyclinder was popped out. ...
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Sep 11, 2010 | Office Equipment & Supplies
Restore setting instruction
You can restore the factory settings in either of the two ways:
Go to Tools>Settings>Phone>General>Original Phone Settings.Then you will be asked to enter a lock code.By default the lock code for all nokia phones is 12345 unless or other if you have changed the lock code you should remember by this time and enter it.
Or else backup the user data (contacts, messages or SMS, notes, calendar entries, etc) if you’re able to (i.e. the phone is not locked).
1) Power off the phone.
2) Press these 3 keys simultaneously: CALL key, ASTERISK key (i.e. *), THREE key.
3) Don’t release that 3 keys.
4) Press the POWER button to power on the phone again and wait.
5) After the NOKIA logo appears, the “Formatting…” keyword will appear after couple of minutes. Now, you’re safe to release that 3 keys.
Finally, the N73 should have been formatted (hard reset) and ready to configure the phone as if it’s just out of the box.
Thank you !!
Jun 17, 2010 | Nokia N73 Cellular Phone
Schlage BE365-CAM  BE365CAM619 Satin Nickel Electronic Security Camelot Elec Logo
76 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
