I have optimum tv and suddenly have no sound on any channel exceot for the channel guide, The TVs in other rooms are fine, so its not the service. Did I hit a button by mistake?
SOURCE: No Sound On Some Channels
Press the MTS Button
Posted on Jul 12, 2008
SOURCE: Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Posted on Nov 14, 2008
SOURCE: tv guide on our LG tv
It is NOT the main board. You need a V CHIP UPGRADE "epk file" Email me and I can walk you through it, very easy introspectionx2@yahoo.com Put "TV GUIDE" in the subject line
The problem started with TV GUIDE messing with things while they are doing their digital conversion
Posted on May 14, 2009
  • 8457 Answers
SOURCE: dynex flat screen- cogeco box- guide works then goes blank
Not the remote.It the Cogeco box.The box data's it out of dated,some time this happen.Unplug the Cogeco box about an hour,replug the box.Let it update it software.Goto the tv setup goto CH. rescan it again,all the tv channel should be back.
Posted on Jul 09, 2010
SOURCE: No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Posted on Oct 11, 2010
Hi, We have a Panasonic Viera Plasma TV. The TV was on when all of a sudden we heard a few clicking noises and then the picture was lost and a 'no signal' message was displayed. We tried other channels...
It sounds like you have taken the steps to isolate the problem to the TV. it seems to be a bad tuner on the Main board. The no signal displayed indicates the TV is otherwise okay. If you have a DVD player or other source you can connect, and you get a picture, then your TV has a bad tuner for sure.
Feb 21, 2015 | Panasonic Televison & Video
Tv screen goes black after 15-20 seconds
It's not the TV from what I can tell. I would start complaining about it and say you want a brand new box. Not used. They tend to give out boxes from people who previously had them and either didn't pay their bill or moved and clean them up.
Dec 30, 2012 | Televison & Video
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
I bought a new Sony ex4/40 tv and programmed my DISH Network remote control for it. Everything works fine when the all the lights are on in the room. Can't change the channels or go to the guide function...
Hello, the problem that you are having is fairly simple to solve. The tv is causing interference with the remote. It sounds like you're at TV1, and TV1 remote is an IR remote. You need to get a UHF remote, and that will stop the interference so that you can continue to enjoy your tv! You can e-mail me at becki.barned@dishnetwork.com if you have any questions or concerns.
Becki Barned
Nov 03, 2010 | DISH Network IR Remote Control
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
We have an Emerson 20inch tv that suddenly lost it's color.
Do a reset to this TV and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 26, 2017 | Emerson EWL2005 20 in. LCD Television
JVC Rear Projection
If you still can see the DirecTV guide and menu, the problem could be on your satellite receiver and not the TV. Unplug your receiver and plug it back.
If the rebooting did not work, I would suggest to swap the satellites receivers and see if it works.
Good Luck.
Mar 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
VCR not working with TV
What you state cannot be logical. If picture is freezing, then the VCR is at fault. But you state that the VCR works fine when played, and viewed on another TV. So, the only explanation I can think of is that there is some thing faulty with your VCR. Probably, when you play a tape, the picture freezes. This could be 'cos the Capstan motor of the VCR freezes. Common problem with aged VCRs. Just requires a spot of grease, and service. IT CANNOT BE THE TV AT FAULT!!!!
Aug 22, 2006 | Toshiba CZ32T31 TV
Televison & Video Logo
454 people viewed this question
Top Televison & Video Experts
