Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Need to know complete fuel line routing - Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
  • 7,733 Answers
Look at eReplacementParts.com and the parts diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 15, 2010
I need the fuel line routing for an 07 chevy avalanche with 5.3L engine. Which line on the fuel pump is the pressure line? where does it go from pump?
Bruce, look for the fuel line running along frame rail with the gas filter attached, this will be the high pressure fuel line that feeds the engines fuel rail/injectors. searched the net and could not find a lot on the fuel lines for Avalanche. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CK159 259 359 for Chevrolet Avalanche
Pt 1 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Pt 2 2007 Chevy Pickup Fuel Pump Replacement At Ray Shop
Aug 19, 2016 | Fuel Pump With Sending Unit Chevy...
Fuel line routing on carbs to pump
Boatman, Is this for a motorcycle or boat? For better answer RE POST year make model and your complete question, so we at Fixya can answer your question effectively.
Fuel line routing on carbs to pump Google Search
Apr 21, 2016 | Motorcycles
1991 XJ 600 S fuel and vacuum line routing
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1991 XJ 600 fuel and vacuum line routing Google Search
Fuel line diagram
Yamaha XJ600S 1992 Service Manual
OEM parts for Yamaha
Yamaha Diversion XJ600N Owner Manual
Aug 18, 2013 | 1992 Yamaha XJ 600 Diversion S
1992 Honda CB 750 Nighthawk fuel line routing
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1992 Honda CB750 Nighthawk fuel line routing Google Search
http://45.63.74.91/cb750-fuel-line.html
Honda 1992 CB750F2 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Feb 10, 2013 | 1992 Honda CB 750 Nighthawk
Need fuel line map
Hi, Robert for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yamaha xv535 Virago fuel line routing Google Search
1983 Yamaha XV500K Fuel Vacuum routing
Yamaha XV 535 DX Virago Service Manual
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-16_110.pdf
Nov 20, 2012 | 1988 Yamaha XV 535 Virago DX
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
The fuel line in the tank connects to the nipple. It then goes into the small hole in the tank and then the fuel line from the carb connects to the nipple. This line is the line that is attached to the body of the carb, not near the plate.
Jan 18, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
I need a diagram for the fuel lines on 1997 kawasaki vulcan 750. i took the fuel lines loose and i don't know where they go
Hi.
There is no "diagram" showing the whole routing of fuel lines in the bike. You need to use different diagrams in Fuel System section of the service manual. Fuel system section starts at page 15 in service manual, but what you really need starts at page 40. I have posted fuel service manual at the end of comment.
There is one forum where users discussed the routing. One user has colored the diagram from service manual to indicate lines routing. Here the diagram:
Here the forum, I quote:
"The red and yellow are the fuel lines that go to the petcock. The green one you left unmarked also goes to the petcock. The line with a question mark is a vacuum line that connects to a part in front of the battery along with the larger lines to the cylinders."
Here the service manual in PDF format.
Regards.
Ginko
Sep 05, 2011 | 1988 kawasaki VN 750 Vulcan
Need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Jun 01, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
69 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
