Question about Hayward Pool Products HAYWARD 1 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP -
I have a Hayward pump that is making a wining noise.
    President:
  • Hayward Pool... Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 03, 2010
05 ford fx4 5.7 v-8 engine wining noise
Why would you be low on trans fluid?
It has to go somewhere
Find out where
That noise was trans pump noise
Hope you don't have any damage
Jan 06, 2013 | Cars & Trucks
Can't get my Hayward Northstar SmartMax pump to pull water, it only makes a noise and does not pump water
Have you looked at the vanes in the impeller? if they are significantly clogged nothing will pump or flow.
Oct 24, 2012 | Hayward 1.5 Hp Northstar High Performance...
My Hayward pump was very noisy but now trips the breaker. I can turn the impeller from the rear pretty easily.
Hayward is synonymous with junk. Let me guess. It's been in service for about two or so years when the noise started. Eventually the motor will burn out. I've gone through two motors and a diffuser on my Hayward pump. It's already making noise again.
Jul 16, 2012 | Hayward Pool Products Hayward Power Flo LX...
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
VIBRATS ON START UP AND MAKES WINING NOSE
check the fuel lines for bends/ pressed points check fuel filter may be clogged check spark plugs and wires
Nov 03, 2009 | 2004 Audi S4
My hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Sep 29, 2009 | Hayward 1.5 Hp Northstar High Performance...
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward Pool Products HAYWARD 1 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP - Logo
159 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
