Question about Lutron #DVW-603PGH-WH 600W White Single Dimmer
The on-off switch for the dimmer is "loose" and does not turn the light on anymore.
There are no repair parts for in-wall electrical devices.
When they go dad you buy another.
Lowes and Home Depot carry inexpensive dimmers.
Look for 3 things:
1) Wattage: most off-the-shelf dimmers are 500-1000Watts. Add up total wattage.
2) If you are dimming incandescent bulbs, dimmer package will say tungsten or incandescent.
Package will say florescent if dimmer also works for florescent bulbs.
3) If dimmer is 3-way, with a dimmer on either end of a room, many times the dimmers are sold as a package of 2 dimmers with 1 dimmer that controls the other dimmer.
Lutron dimmers
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Leviton dimmers
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=15265&minisite=10025
Posted on Nov 15, 2010
4 Suggested Answers
SOURCE: Richmond 500 grid dimmer switch keeps failing
Too much load? Disconnect some spots and see what happens.
Posted on Feb 02, 2009
VtToolMan
  • 704 Answers
SOURCE: I'm attempting to wire a 3 way switch with a dimmer
Hello Chris,
What has happened, is that you've got th two "traavelers" reversed on the plain toggle switch. These are the RED and BLACK wires. turn off the power and reverse the position of these wires and the switch should work correctly from either the Dimmer switch or the plain switch.
Here's a link with a diagram, which might not exactly match your circuit configuration, but you can also watch a short video that explains how 3-way switches work.
It is just a matter of getting the travelers on the correct screws in order for the circuit to operate properly from either switch. Also, depending on the type of dimmer you've installed, the other switch will only turn the lights on at the dimmer setting that you've left the dimmer switch in. So be sure that you're not turning the dimmer all the way down before you shut it off (at the dimmer) otherwise, the other 3-way switch won't be able to turn the lights on, regardless of whether you've got the travelers in the correct locations.
Remember to turn the power off to the circuit you're working on while you rewire it and flip the breaker back on when you're done.
http://www.electrical-online.com/3waydiagram.htm
Hope you find this Very Helpful and best regards!
Posted on Nov 17, 2009
SOURCE: My rotary dimmer doesn't switch 3-ways. I have to
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Posted on Dec 01, 2010
1988 GMC Van headlights cut off when I tilt steering wheel.
You need to check the wires in the steering column. Take the column cover off, probably phillips-head screws, so you can see the wires. Somewhere the tilting function is putting pressure on the wires to the dimmer switch. It may be pulling loose a connection, just a fraction, to lose contact. You may also need a new dimmer switch. Or a multifunction switch if the dimmer switch is attached that way. The headlight switch is on the dash, isn't it? If it is, the headlight switch is not the problem, it is the wires in the steering column or the dimmer switch. If the dimmer switch fails, you will have no high or low beams, no head lights at all.
Jan 11, 2015 | GMC Cars & Trucks
Lutron Dimmer: 'IN' does not always equal "ON"
These are probably three-way switches being used as two-way. If so, then the switches will have three terminals, but only use two. Just switch one of your wires to the other terminal. If the light will not light, that was the wrong wire. Don't mess with it without turning off the breaker! Good luck.
Feb 25, 2013 | Lutron LG-600P Lumea Single-pole 600 Watts...
Center console park and drive lights replacement
did you check the dash light dimmer ! if yes the switch may be bad. check for a loose wire to dimmer switch also. good-day !
Dec 17, 2011 | Toyota Corolla Cars & Trucks
My master dimer and companion dimer led lights went out and I can't turn the light fixture off. The light stays on but the switch does nothing. Do both switches need to be replaced or just one and how do I...
If you can't turn them off, then chances are that the dimming element within the master dimmer shorted. Some dimmers can get triggered by a hellacious bulb blow-out where a surge of current will ruin the semiconductors in the dimmer and, basically, short it out. If that's the case, I can't guarantee that nothing was broken in the companion, but zero dimming capability usually means the master dimmer.
Also, because its shorted, there's not voltage left around for the dimmer's to use to power up themselves - that's probably why the LEDs on neither device are turned on anymore. Replacing the dimmer should fix that.
Jan 09, 2011 | Cooper Wiring Devices Aspire Smart Dimmer...
What would cause a dimmer to work and then cut off and then it will turn the lights back on in about 20 to 30 minutes
I might suspect a loose connection on your wiring but also you have to consider a faulty dimmer switch.Try to tighten the bulb on its receptacle and the lock screw of your dimmer if it has (Your breaker must turned off avoid you from an electric shock). If the problem still there I've advice you to buy a new dimmer switch to swap for a suspected one. If the problem still there then you need an electrician to isolate the trouble.
Thanks for using fixya...
Jan 09, 2011 | Leviton Decora Light Dimmer Switch
I have installed a 2-way dimmer switch in my dining room. I was able to install it and it works great. However, on the other side of the wall where I installed the switch, I have another single way...
If I understand correctly new dimmer is in different box than outdoor switch.
And outdoor switch controls different light than new dimmer.
Both new dimmer and outdoor light are on same circuit breaker, and that breaker is not tripped.
Outdoor problem could be related if loose wire inside dimmer box also feeds over to outdoor switch. More below.
Here's how I would troubleshoot problem.
1) Check outdoor bulb(s). This step can be big time saver.
2) Pull outdoor switch out of box a bit so you can see and test wires.
3) If wires are pushed into quick connects located on back of switch, these connects get loose. Moving switch usually causes loose wire to connect again, so turn switch ON-OFF and see if outdoor lights work. Sometimes switch works fine after quick connects reconnect. If quick connects are bad, use tiny screwdriver in slot next to connect-hole to release wire. And then connect wire to screw terminals on switch. Or replace switch.
4) Turn switch to OFF, use tester and test both screws on switch to bare ground wire. Tester should light up on one screw. If tester does not light up, then switch is not getting power, and that wire has to be tracked back to see where short is.
a) Look if one of the black switch wires is connected to other switch, or connected to other black wires inside same box. This wire might have come loose.
b) Look at white wire inside same box and make sure they are twisted together and covered with wire nut.
c) Now here is where dimmer could be related ... if white wires are joined together in dimmer box, they could have come loose if they were not properly twisted together and covered with wire nut.
http://waterheatertimer.org/How-to-twist-electric-wire.html
5) Turn switch to ON and test again. Tester should light up on both screws. If switch does not light up on both screws, then switch is bad. Replace switch.
Add a comment if you need more help.
Dec 01, 2010 | Leviton Decora Light Dimmer Switch
My Lutron dimmer/lights suddenly will not turn on. all electricity works throughout the house. The green light that usually is lit on the panel is not on either. any suggestions?
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Nov 15, 2010 | Lutron #MA-LFQHW-WH 300W White SP Light...
3-way dimmer dead
It could be a loose connection, and it could be a loose connection on the OTHER 3-way switch across the room. Also, verify that the dimmer is rated for the fixture(s): add together the wattage of each individual light bulb that the dimmer controls and make sure that the dimmer has a higher wattage rating. If it isn't, you might have burned up your dimmer (and risked an electrical fire). Hope this helps!
Aug 31, 2009 | Leviton Decora Light Dimmer Switch
Lutron #DVW-603PGH-WH 600W White Single Dimmer Logo
190 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
