Question about Samsung SP-R4232 42 in. Plasma HDTV
How to connect roku device to wall mounted TV
Pros And Cons Of Roku
Roku is one of the best streaming devices to stream the videos, movies and TV shows.
Pros of Roku
The Roku offers user interface and Roku app in cheaper packages.
Roku does not require the separate box or HDMI cables to connect the TV from the stick plugs.
It has screen mirroring features that display the screens of the mobile device on you Roku tv.
It has the search function to search the lists of channels from the channel stores.
It provides headphone jack for private listening.
Cons of Roku
For the Network connection, Wifi is the only option
You need HDMI cable for Roku stick because it lacks analog and digital audio outputs.
If you need further more information about the roku products contact the roku customer service team @ +1-844-965-4357 and you may visit https://www.rokuactivationcode.com/
Apr 06, 2017 | Internet Computers & Internet
How to install and set up roku premiere
1. In order to activate Roku premiere you need to link to your TV port, you can use HDMI cables.
2. Now, connect it with power connection and turn ON power
3. If you see a Roku logo on your TV screen, go ahead and select 4. language according to you.
5. Choose network connection and connect Roku with internet.
6. Wait for rebooting and let install latest version of Roku software.
7. After installed software, you can see a Roku activation code
8. Go to roku com link account and enter this code here.
9. Create account and activate your Roku device.
10. At the end, you can add you favorite channels from Roku channel store.
You can also more information at
Setup Roku com link www roku com link Activate Roku com Link
Jan 08, 2017 | Roku Televison & Video
How do I connect my Roku?
1.Connect the Roku Stick to the HDMI port on your TV.
2.If your Roku player has an Ethernet port, you can use the Ethernet 3.cable to connect the Roku player to your router.
4.Insert the batteries to your Remote carefully.
5.Connect the power to the Roku player and connect the power adapter to the electric outlet.
6.Choose the language when the Roku player is turned on.
7.Choose your wireless network from the list then connect your Roku player to the internet.
8.Once connected your Roku player will download the latest version software.
9.Create a Roku account and activate your Roku player.
After creating you can log into your streaming device to enjoy watching your favorite channels on Roku.
Dec 26, 2016 | Roku Streaming Stick
To. Enter the code
I am having problems linking my Roku player, what should I ...
https://support.roku.com/.../208754508-I-am-having-problem...
Roku, Inc.Resolving Roku player activation/linking issues Follow these suggestions if you ...Enter the new code at www.roku.com/link; If the serial number does appear as ...
Roku 3 (Model 4200) - Setup Instructions - Roku Support
https://support.roku.com/.../208754778-Roku-3-Model-4200-...
Roku, Inc.Connect your player Step 1: Connect one end to the HDMI port on the back of yourRoku player. Connect the other end to...
I linked my Roku player but my TV still shows the linking ...
https://support.roku.com/.../208755568-I-linked-my-Roku-pla...
Roku, Inc.First, ensure that your Roku has indeed been activated. ... number is not shown, select "Get a new code" on your TV and then enter the code at roku.com/link.
Roku ' Link a Device
Dec 29, 2015 | Roku 3
How do I hook up a roku stick?
I am guessing you mean the HDMI connector type Roku?
You simply plug the Roku into a free HDMI port on your TV, then switch your TV input to the proper HDMI selection, then start your setup. I believe this also needs to be plugged into the wall for power as HDMI does not supply power.
If you have an iPhone or other similar devices, you can download the ROKU app to control the device.
The link I provided may help. Setup help
Nov 16, 2015 | Roku Televison & Video
How do i find the right web-site to enter my code for roku?
If you want to enter your Roku code then you can click on this link
my.roku.com/link and still if you are facing any kind of problem regarding Roku then click here Click here to get the solution for that.
Mar 06, 2015 | Roku Streaming Stick
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
I have a Roku, which allows me to transfer Netflix films to my TV. Since we no longer have a WiFi it must be attached by wire. I have a Linksys Cisco router. Can yo give me directions on installing both...
Okay, the router "if needed" first. Do you need a router? A router is used mainly to connect multiple devices to one internet connection. The Roku is one, if you have computer(s) also, then yes you need a router. Is the Linksys router wireless?
From the wall the coaxial cable TV/internet cable goes into the cable modem and another coaxial to the Cable box. Wire to the TV as desired. From the cable modem to the router use a RJ 45 cable into the WAN/Internet port. Now use another RJ 45 cable to the Roku and RJ 45's to the other ports marked 1 to 4 as needed for computers. If the Linksys router is wireless you can set up everything wirelessly.
Instructions for setting up the Roku is at the link below.
http://support.roku.com/entries/244199-how-do-i-set-up-my-roku-player
Good luck,
Cullen
May 19, 2011 | Linksys Computers & Internet
Samsung SP-R4232 42 in. Plasma HDTV Logo
192 people viewed this question
Jerry Greenberg
Jerry Greenberg
