Question about Cadence Exercise & Fitness
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
  • Anonymous Mar 21, 2014
    brand new never used weslo 5.9 and the belt doesn't move.
  • 42 Answers
Hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Posted on Nov 15, 2010
My cadence 825 had been unused for a while but now when I insert the plastic key the treadmill starts immediatly without my having control over it. where can I get some maintenance for this machine. Kevin...
RUN the software calibration for diagnose, troubleshooting , fix it.
adjust the speed sensor, clean it and tight the wires connector
LUBE the deck belt+rollers bearing too
SEE THE diagram.
God bless you
Jul 19, 2012 | Cadence Weslo 825 Treadmill Walking Belt
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
Where can I download a manual for a Weslo Cadence 825 treadmill
FitnessRepairParts may be able to sell you a manual if you can't find it anywhere, depending on which version of the 825 you have (there are quite a few.. check for other model numbers on your machine
http://www.fitnessrepairparts.com/part_search/EquipmentSearch/weslo%20cadence%20825
You can also try IconService.com and click on "Manuals" - sometimes they have manuals you can download or purchase.
Oct 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Nov 24, 2009 | Cadence Exercise & Fitness
Candence 825, motor not driving belt, smells of burning
Hi Jill, have you found a solution yet as I seem to be getting a sililar error. Do you get a E02 message and a beep. Thanks Nicky
May 18, 2009 | Cadence Weslo 825 Treadmill Walking Belt
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
142 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
