Question about Dishwashers
Nobel dishwasher, water won't drain away. still sitting in bottom of dishwasher
  • 131 Answers
SOURCE: bosch dishwasher
1. Check for a clog in the air gap:
That's the silver dome on the back of the sink. Not all homes have an air gap for the dishwasher. (Though it is highly recommended!) Lift off the silver cover. Unscrew or unclip the plastic cap on the top. Look inside. Toothpicks are often found there.
2. Check for debris in the sump by:
Remove the lower rack, the lower spray arm, and screens. Use a #15 Torx bit to remove the cover over the drain pump suction. The hole leading to the drain pump is on the left at the bottom. Remove any debris you find.
3. If you find no debris, you almost certainly need a drain pump. After clearing any clogs, if you hear the drain pump humming, but it doesn't turn, replace the pump.
Comment back if you directions for this.
Posted on Mar 12, 2008
SOURCE: Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Posted on Mar 15, 2008
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
  • 262 Answers
SOURCE: Not draining water and water does not shoot out of sprayer arm
try cleaning the drainat the sink alot of time gunk will build up in the connector to the sink very easy to look at as far as one4 sugg it sounds like the motor may be jammed or soething is in the pump you can get the special bit at lowes or your local hardware store i cant rember the size off hand i get them in alot of different sizes at a time so i have them on hand If any one knows the size please let them know thanks
bil
Posted on Jan 08, 2009
  • 1382 Answers
SOURCE: DIshwasher doesn't drain. 3-4 inches of water sits in the bottom.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Posted on Sep 25, 2009
Where can i get a bottom tray for a nobel dishwasher NBFS4 S/S model
nobel dishwasher cutlery tray - Compare Cheap ... - GetPrice
www.getprice.com.au/buy-best-nobel-dishwasher-cutlery-tray_pn9.htm
Results 321 - 342 of 342 - Compare Nobel dishwasher cutlery tray price and readNobel dishwasher cutlery tray reviews before you buy. ... Bottom... more info.
I have a Nobel Dishwasher, model NBFSDEC. I have ... - Fixya
www.fixya.com/support/t24625480-nobel_dishwasher_model_nbfsdec
Jun 13, 2014 - I have a Nobel Dishwasher, model NBFSDEC. I have cleaned the filters ... Dirt left on dishes on top tray; bottom tray washes fine. Apr 03, 2009 ' ...
Household Cleaning Urban Myths: Do They Actually Work ...
www.apartmenttherapy.com/household-cleaning-urb...
Apartment TherapyJan 31, 2011 - com1Line the bottom of a pan with aluminum foil with the shiny side up. .... To get baked-on crud off of broiler pans, oven racks, roasting pans, glass baking .... Burnt pans, if you don't believe in Easy Off (a Nobel Prize for the ...
dishwasher in Scarborough, WA ' Dishwashers ' Gumtree ...
www.gumtree.com.au > Home & Garden
Jan 04, 2016 | Dishwashers
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
May 24, 2012 | Miele 24 in. Novotronic G851SC Plus...
Won't drain. Water sits in bottom during all cycles. Water back up to sink.
Run your garbage disposal and sink water for a few minutes in case there is anything clogging the drain. Also look under your sink in case the drain hose is kinked. That hose might also be clogged but is a difficult job - maybe pro help is needed if you are not comfortable doing it yourself. Last option is that the pump is bad and must be replaced
Jul 08, 2011 | Dishwashers
Once the dishwasher had finished the bottom was full of dirty water which won't drain away and now it wont work at all
More than likely a failed water pump, or blockage that has created a discharge problem. This could cause the circut breaker to trip. So, it is kinda messy, but if you drain the water by hand baling, clean or check the interior bottom d/w discharge intake & screen, reset the breaker, and restart. If the system still does not drain it's probably pump failure. I don't think people actual replace the pump, they just get a new d/w unit. Unless there is warranty coverage.
May 25, 2011 | Hotpoint Dishwashers
My dishwasher will not drain
You will need a specialist to come and fix that. You might mess up your whole drainage system doing it by yourself.
Jul 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
