FixYa.com
Tags:
Uniflame 200209 Open Flame Patio Heater
Lack of heat
posted by jrj2 on Jun 19, 2008
Hi. I have a Uniflame "Richmond" model grill bought at Walmart.There are no briquettes with this model. My problem is that, even with a full tank of propane, I cannot get "real" heat from the unit. I feel that the cover above the flame inhibits the true grilling experience. It is very frustrating. Any ideas please send to me by email at jrj2@shaw.ca
Thank you.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 19, 2008
Helpful (85)
Fire876
Rank:Master Master
Rating: 88%, 12 votes
The plates protect the burners and help disperse the flame more evenly across the grill surface. Make sure the tank is completely open (knob on top of tank) and that when the burner is turned up to high, the flames out of the burners are about 1 1/2 to 2" long, mostly blue in color. If they are smaller, and the tank is open all the way, the regulator hose may be defective.
Rating Locked! (?) jrj2 has rated this solution as Helpful
Can you Help with these Heaters problems?
Heaters
marvin quartz heater model 4940...
marvin heater model 4940 rotary... Answer This...
Heaters
detaching heater unit from its...
I want to remove the heater... Answer This...
Heaters
ROCKER SWITCH DIAGRAM
i need to see a wiring diagram... Answer This...
Heaters
heater
when I turn my thermostats on... Answer This...
Coleman Gas Heater for home
We have a coleman gas heater,... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
