Question about Maytag Neptune MDE6700A Electric Dryer
I own a Maytag Model# MDE6700AYW: Problem: When powered on "65" in display; I turn selector to a setting = "Clicking" noise on circuit board transformer, but no action. 1) A Sears Appliance Technician ordered a replacement Motor; 2) The Motor was replaced today but problem is still occuring - do I order the Circuit board?
  • 7 more comments
  • thestoneman1 Nov 17, 2010
    Hi jyackle5 - I received the board today, replaced it and it is doing the same thing... AHHHH! (sorry - been without a dryer for a few weeks). There isn't much left from what I am looking at - any other suggestions are greatly appreciated thank you much
    I took everything apart again and reseated the connections with same result... no luck, same symptom? just clicks... (new motor, new PCB, all vent passages are clear, dust cleaned out) is there a way to jump some of the sensors... to bypass them to help isolate? That's what I did to the door switch) to check after I reseated the white wires while still apart
  • thestoneman1 Nov 18, 2010
    I am choosing to ask another expert, thanks: Previous recommendations seem logical troubleshooting steps: So far I have
    1) replaced a motor
    2) the Printed Ckt board (PCB)
    3) reseated all of the white terminal connections...
    RESULT: same symptom, I turn the knob on it chimes, LED lights up; I push the knob to start but nothing happens - the relay on the ckt board clicks but nothing happens.
    I did replace the Main Circuit board PCB = same symptom (I guess you didn't read the additional comments). Will the LEDs still light if the source power is off or would I get a code? thanks
  • thestoneman1 Nov 19, 2010
    jahn27 I bypased thermistor 1 and that did it!! I wish I knew about this site before I called Sears! I would have saved a lot of money! I would have checked this stuff first.
    Jahn27 - You are not going to believe this - unbelievable - now the washer is on the blink! Murphy must live here!! IT's not draining - getting ready to rip it apart. Probably be floowing up for more advice!! MAH6700 WWW
    I accepted and will surely highly recommend you to friends and family
    Understood - had it not just been a clog, I would have done so. Again appreciate the guidance and the pictures - that really helped.
  • Omar Noble Oct 17, 2012
    Holy **** Jahn27 you rock dude I was able to figure out my proble in less than an hour with this great tip thanks a million even though this post is 2 years old it was very hepfull thank a million Jahn27.
    President:
  • 1,554 Answers
It sounds like the problem is a blown safety thermostat located on the blower housing or the belt cut-off switch is not functional. Verify any of these conditions by passing the safety thermostat then the belt cut-off switch if necessary.
Disconnect power and locate the safety thermostat (thermostat 1) on the blower housing. Disconnect the wires. and connect them together then insulate it properly. Reconnect power and start the dryer. The safety thermostat is indeed blown and needs to be replaced along with the thermistor if the dryer starts.
I own a Maytag Model# MDE6700AYW: Problem: When - jahn27_38.jpg
Bypass the belt cut-off switch keeping the safety thermostat bypassed if the dryer still doesn't start. Replace the belt cut-off switch if the dryer starts. Start the dryer with only the belt cut-off switch bypassed. Also replace the safety thermostat and the thermistor if the dryer stops working.
Just in case the dryer doesn't heat up, bypass both the high-limit thermostat and the thermal cut-off on the heater housing. Replace both the high-limit thermostat and the thermal cut-off if the dryer heats up. Do not use the dryer with any safety component bypassed due to fire hazards. Bypassing them is for troubleshooting purposes only.
Check the heating element for broken coil if the it doesn't heat up. Replace the heatiI own a Maytag Model# MDE6700AYW: Problem: When - moz-screenshot.pngen. Redo the moz-screenshot.pngmoz-screenshot-1.pngtroubleshooting with the high-limit thermostat and the thermal cut-off above if the new heating element still doesn't turn on.
Posted on Nov 18, 2010
  • Jahn27
    Jahn27 Nov 18, 2010
    Please make sure you accept the solution that you helps you solve the problem.
  • Jahn27
    Jahn27 Nov 19, 2010
    It's my pleasure to help you determine the problem and address it.
    Regarding your problem with your washing machine, I suggest you post it as a different thread.
  • Maytag Master
  • 12,061 Answers
Well you really don't have much option now do you. The Main circuit board, is most likely the culprit.
http://appliancedigest.com/index.php?/files/
Also to assist you i include a link above where you can download a service manual. This has all the info you need to troubleshoot and repair your Dryer.
That "Clicking"noise you hear is indeed the sound of an overloaded and faulty power supply,on a main board.
However you DO need to check ALL external sensors, to ensure that they aren't the culprit.
  • 8,197 Answers
Welcome to FixYa!
If the display has a 65 and all you here is a click on the board that means that you have a short on the board.
You will need to replace the board to get the machine to work again.
Good Luck
Posted on Nov 15, 2010
  • Jyackle5
    Jyackle5 Nov 17, 2010
    The only other thing that just came to mind is that there is a short on the netural line. They are the white wires that run through the machine. You need to redo all the conections.
  • Jyackle5
    Sorry now I am at a lose . I do not know what can be wrong. What you have done should have fixed the probllem.
Front console removal help for Maytag MDE6700AYW dryer.
Go to www.repairclinic.com and enter MDE6700AYW. You will be presented with a list of common repair parts and may be able to view a generic Maytag video showing disassembly.
Dec 25, 2016 | Maytag Dryers
Maytag Neptune dryer, model mde6700ayw, cycle selector knob will not change cycles. It gets stuck on a random cycle even when I power off, power on. Tried to put in service mode but as the cycle selector...
you have a problem with this dryer,the computer board and other parts are no longer available,your better off replacing the dryer.if you go here you can see the parts
http://www.searspartsdirect.com/model-number/MDE6700AYW/3048/0151200.html?searchType=modelSearch&q=mde6700ayw&searchTerm=mde6700ayw
Sep 06, 2017 | Maytag Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
How do I run the Membrane pad check on dryer, Maytag model MDE6700AYW
To Enter Service Mode:
Document 1
Document 2
Document 3
I didn't see your model number posted so hopefully this is for the right model.
Oct 14, 2012 | Maytag Dryers
I have model # MDE6700AYW (Maytag Neptune electric dryer) Error code T5, service codes 0, 19 and 76. Can anyone tell me what part needs to be replaced?
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Here is a link to the part in case you need it.
Aug 23, 2011 | Maytag Neptune MDE6700A Electric Dryer
Maytag Model # MDE6700AYW lights up but will not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 17, 2010 | Maytag Dryers
Dryer has power, all lights come on, however no action. It is a neptune model (p) MDE6700AYW
first ck the power - turn it off at the breaker box and back on ( you may have lost one leg of the 220 / ) if thsi didn't correct problem it may have over heated due to restricted vent / this causing the safty themo to stop the dryer / it is a one time themo and will require replacement. and vent will have to be cleaned . hope this will help **** ..
Dec 04, 2009 | Maytag Neptune MDE6700A Electric Dryer
65 inch clicking hitachi
The clicking your refereing to is your relay. The first component that voltage entires from the cord. from ther it goes to 2 rectifiers one for standbye voltages and one for the operating votages for the various operating circuits for the set. What is your model number? Alot of Hitachis have built in diagnosis . Try pushing the AVX &power button on the set and see if the light blinks a code. Let me know if it blinks, also provide your model number.
Jan 19, 2008 | Televison & Video
Maytag Neptune MDE6700A Electric Dryer Logo
749 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
