Question about Kodak ESP 5 Printer
Black ink is not dispensing right - Kodak ESP 5 Printer
  • Kodak Master
  • 4,338 Answers
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Posted on Nov 15, 2010
Clean the print head for an HP F380
If the cartridges are new, make sure you removed the, (sometimes clear), tape that the manufacturer places over the shinny metallic ink distribution slots, (shinny objects on the underside of the cartridges, like the previous answers have described). Otherwise, make sure the cartridges are the correct model for your printer, and I use a dab of alcohol on my q-tips to clean off old dried ink from the contacts. The contacts are very obvious once the cartridges are removed. Make sure to unplug the printer once you have removed the cartridges to access the contacts, before cleaning. And be gentle with the contacts, rub gently. And clean the cartridge contacts and ink dispensing slots as well, and gently as well. As previously mentioned, you should get ink on the q-tip when cleaning the ink distribution slots. Three colors, yellow blue and red from the color cartridge and black from the black cartridge. So clean the contacts first, then do the ink dispensers last to avoid adding ink to the contacts with a ink soggy q-tip. Good luck and be gentle.
Feb 13, 2015 | HP DeskJet F380 All-In-One Printer
I would like to print some color pictures in black & white but I cant get it to do it. Any ideas
The black ink produces dark images while color ink produces multicoloered images. Once pictures that appear in color on the computers word documents are dispensed for printing, the color ink makes possible requests. It is impossible to request black charaters from colored ink on the printer.
Feb 04, 2011 | Lexmark X4580 InkJet Printer
Color ink cartridges not working. I tried cleaning the printer heads many times and also followed pineworks' suggestions. Still doesn't work. I even put in some new ink cartridges. Only the black cartridge...
turn printer off. take all ink cartridges out. look at where the ink is dispensing to see if the tape is still on the cartridge of blocking the ink from coming out, if so remove. when touching the area where the ink comes out, be very careful.
look into the printer where the ink dispenses into the printer, look and see if anything is blocking the hole.
hope this works and good luck
Apr 30, 2010 | HP Photosmart 3210 Printer
Does not print the black colour; all the other colours are perfect, except the black. I replaced the cartridge ( a completely new one ) and still does not work.
Try to run Head Cleaning utility of your printer. This will force your printer to recharge so that it can dispense black ink that you placed recently.
If you are using Windows:
  1. Click Start button => Settings => Printers and Faxes
  2. Locate your printer icon. Right click on it and click "Printing Preferences".
  3. Look for the "Maintenance" Tab in the window that appears. There you will see commands for "Alignments" and "Head Cleaning" or some similar commands.
I suggest that you just perform this once since Head Cleaning consumes ink.
Feb 10, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Black is very bad,
bad means to poor
then check ink supply for black
check cartridge motor by removing black cartridge and inputing component test code 009-011 does it rotate black cratridge moter
similarly for dispense motor 009-031 for lower side gear
Feb 01, 2010 | Xerox DocuColor 12 Printer
Brother MFC 210C black ink not working
DID U REMOVE THE PLASTIC STRIP FROMT THE BOTTOM? IF NOT, SOMETIMES INK GETS OLD AND KIND OF DRY....SO I CLOGS UP WHERE THE INK DISPENSES.......ALL YOU HAVE TO DO IS DAB YOUR FINGERTIP IN WARM WATER AND TOUCH THE AREA WHERE THE INK COMES OUT..........THIS ALWAYS WORKS FOR ME
Sep 22, 2009 | Office Equipment & Supplies
I'm getting a great deal of distortion (choppy ink coverage) along the left and right side of the paper, on my Riso RZ220.
The drum needs adjustment, it's not dispensing enough ink. On each end of the drum there is some small plastic covers with one philips screw. These are to control the scrapers to add more ink. Adust them slightly to dispense more ink.. they have plus and minus on them to tell you wich way to go. These things get out of adjustment as they get older. Also ink starts to dry in the screens making them clogged.
Aug 07, 2009 | Riso RZ220 Duplicator
There may be an air bubble in the black tubing, it will take several more cleaning cycles to clear. You can tell it to clean only the black and save the other inks.
Jul 01, 2009 | Brother MFC 490cw Color Inkjet...
The new ink cartridge is not dispensing its color.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Nov 18, 2008 | Epson Stylus C84 InkJet Printer
Installing new cartridge
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Mar 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Kodak ESP 5 Printer Logo
193 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
