Question about Westinghouse Refrigerators
I require a wiring diagram for a refrigerator Model RJ202T. Auto defrost dose not work. Can you help please
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
SOURCE: kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Posted on Feb 19, 2008
  • 1073 Answers
SOURCE: Problem auto defrost refrigerator
loaded question any COULD be bad a volt ohm meter will tell you whitch one is bad
if this is a ge sxs i would check the defrost heater first
Posted on Jun 24, 2008
SOURCE: HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I`m actually working on the same problem. defrost problem and no wiring diagram. I defosted evap. coil to get by weekend and will look at it again monday 8/4/2008. same refrigerator.
Posted on Aug 04, 2008
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
Defrost heater not starting
4e2ea43c-1c5e-4568-92ef-e26d3e1d4b98.jpgWhat is the model number of the refrigerator so I can look at wiring diagrams and other reasons the defrost heater may not be working? Have you checked continuity through the defrost thermostat? Sea Breeze
Jan 25, 2013 | General Electric WR51X442 DEFROST HEATER...
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Can you tell me if N.E.F fridge freezer no k4204x6gb automatically de frost Thanks
Hi.
Yes.
Your freezer is definitively an auto defrost model. Please see the link below:
NEFF K4204X6GB Fridge Freezer With Auto Defrost
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Sep 09, 2011 | Refrigerators
Where can I find a diagram for the 1999 kenmore refrigerator coil heater, defrost thermostat, and freezer (evaporator) fan?
Hello, Thank You for using FixYa. I will be helping you today.You can try sears parts direct enter your model number and sometimes their parts look up also has the wiring diagram.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Refrigerators
Kenmore 10674264400. What is the correct wiring connections for the defrost timer board?
here is no specific wiring diagram available but I may be able to help you with this problem.There are tech sheets with wiring and tests available for most model refrigerator.
From the description you give you most likely have a defrost problem. If the defrost system stops working then ice builds up on the coils and eventually causes air flow and cooling problem. If you have a top mount refrigerator the the instructions to enter and run the defrost system are in the image below.
The heater can be checked for how many amperes it's drawing or just listen for the sizzle and pop as the ice melts around the heater.
A defrost failure can be a problem with the timer/control, element or defrost thermostat.
I include additional wiring schematic diagrams of other brands (Maytag), you can compare, wiring connection of the defrost system using adaptive electronic defrost control board instead of the timer.
I hope this information helps with this problem. see in my Blog http://trend2download.blogspot.com for more info and submit another question with any additional details for further assistance.
Aug 20, 2010 | Kenmore Refrigerators
Freezer works fine but no cold in refrigerator
Because Your model has an adaptive defrost board Part number Click Here=> 241508001 it is the most likely reason for the defrost or not cooling problem. Frost or snow will be collecting on the freezer walls. Click Here=> Frigidaire Controls FRS6LF7JW3 number 23 is the adaptive defrost and 115 is the auto damper and I need you to make sure it is opening and closing properly. This refrigerator is a little complex because the thermostat, auto dampre and Adaptive defrost are all wired together so don't give up until we locate the one of the three causing the problem. setting warmer freezer should open damper and cause colder fresh food. Stick with me on this. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Click here=> Wiring Diagram note wire 6 goes to auto damper so if ADC board or a thermostat defevtive that will be the cause.
Mar 24, 2010 | Refrigerators
Defrost cycle not defrosting
Hi
Please check the defrost timer at the back of your refrigerator and also check the defrost thermostat. Defrost thermostat wiring(part #240) could be loose. You'll need to remove the back panel, held in place by 5 screws. Locate the defrost thermostat and disconnect it from the wire connection to another part. Due to the connection requirement, you may need to cut the wires from the original part and splice it with the connector with wires to the new part. After securing the spliced wires and covering in electrical tape, replace the panel and all the screws.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Jul 14, 2009 | GE Refrigerators
I have a whirlpool refg that will not auto defrost.
Inside your fresh food compartment is a defrost timer hidden behind the tep. control panel. Most panes have a hole or plug you may need to remove to turn the timer. I need you to turn it clockwise slowly until compressor stops running. Wait about 30 min. to see if the refrigerator comes back on. If not we need to replace the defrost timer part # 482493
That is providing the model number above your post is correct.
Model Whirlpool ET22RKXG?
Let me know, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool 21.6 cu. ft. Top Freezer...
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side refrigerator model 106.56532400
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
81 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
