Question about Aiptek MPVR Digital Camera
Hello, my MPVR is not functioning: it activates and the screen goes blank no response- the charging light and off/on lights stays on- only goes off when disconnected or battery removed.
  • 3,083 Answers
This can be happening for a few reasons, most of which would require servicing, but you can try one thing to hopefully fix it. Clean the battery terminals, on the battery and also inside the camera, with a qtip and at least 90% isopropyl alcohol. Also, make sure your battery is fully charged, and good (measure it for the required voltage).
If these things don't help, you'll have to contact Alptek for advice and support. Refer to your manual that came with it.
Good luck, and hope this helps.
Posted on Nov 15, 2010
The charging light will come on, but when I turn on the kindle the green light comes on for a second then goes off and the screen stays blank
the battery has died . take it to a computer shop and see if they can replace the internal battery
Dec 05, 2015 | Tablets & eReaders
4206p blue led light not functioning
As per my earlier response , check your charging system and battery on your vehicle. You need to determine if something is depleting the battery of your vehicle or if the charging system is ok. Alternator belt and battery are first ..
Feb 19, 2014 | Python 4206p Responder Le Remote Start...
Problem with kodak z650 camera wont stay on
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Jan 21, 2013 | Kodak EasyShare Z650 Digital Camera
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
"z" light comes on, then battery charge indicator -Doesn't start!
If there no indicator of power on the laptop , There could be two problems either the AC adapater is bad or the motherboard connector pin or board is faulty.
If you see power light activity , but the screen is blank. try connecting an external monitor to the laptop. Press the Fn+ F8 key to toggle the screen to the external display. If you see the display on the external screen then the LCD is bad . Otherwise its your video card.
Thanks for using fixya
proton
Aug 14, 2009 | IBM ThinkPad T40 2373 Notebook
My laptop will not load up it is charging and the power light is on but there is just a blank scrren please help my i just bought it
Can you hear it doing various thinks, ie the hard drive light activity, whilst the screen is blank?
I am thinking that the button the change the screen to the TV or scart socket has bee pressed which means you can choose between the laptop screen and tv screen or an external monitor.
Usually actived unsing combine "function" and "CRT/LCD" buttons (or similar names).
Sep 16, 2008 | Computers & Internet
Olympous Master Camera Problems
If the lens stays out then it would appear to be the fault lays there.
Check with Olympus support or in the camera is still under warranty retun it to the seller.
There is no self repair option.
Aug 22, 2008 | Olympus FE-280 Digital Camera
Camcorder lcd screen light blue (blank) and camera won't turn off...
Sounds like maybe a connection somewhere inside the camera came loose? Or maybe the camera's firmware (camera's operating system) is damaged? I'm honestly not sure what would cause this. You could try contacting Aiptek customer service or you could post this issue at http://forums.steves-digicams.com/forums/view_forum.php?id=92
and see if anyone there is familiar with this problem.
Nov 12, 2007 | Aiptek MPVR Digital Camera
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Sep 11, 2007 | Panasonic CT-32SX12 32" TV
Aiptek MPVR Digital Camera Logo
32 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Greg Cann
Greg Cann
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
