I have a fredric m30cf ac unit that keeps going out on me it bliks two times red and green and then three times red and then repets itself
    Brigadier General:
  • 3,917 Answers
Thank you for contacting Fixya.com.
From the symptoms that you have posted it sounds that the capacitor which is responsible for having the unit start is not working. It's easy to replace it. Please turn off the breaker. Next please remove the air return grill and filter and you should be able to see it. Sometimes in certain models you might not be able to see it. So in such cases check behind the panel where the electrical connectors are located. It's would also be a good idea to wiggle all the wires, and pass the screwdriver through all connections terminals to make sure they are tight, on RV's, with the vibration they then to tend to get loose from the terminals. Therefore the part you need is called Starting Capacitor and it is located in the same compartment where the electrical connectors are in the outside unit. You might want to remove capacitor and take to an appliance parts store to get a new one.
Please get back to us if you have any further query.
Posted on Nov 15, 2010
Ps3 turns on then turns off and beeps three times
Sounds like a power supply issue. Unless it is showing any other colours after the green light. Red would be ylod which means a phone call to Sony. Try a new power supply and see if that fixes it.
Dec 29, 2012 | Sony Playstation 3 (PS3) Console
TV power comes on but then I just get a blinking green light. No picture or sound.
Make sure your cable input is in properly. The TV might be going into a sleep mode if it not getting an input signal
Apr 03, 2012 | Philips Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
My wife disconnected all the wires to the thermostat, I do not know what goes to what. Reading the installation docs I get it that white is to white yellow is to yellow green is to green. But for the...
The Red wire goes to the RC-R with the jumper as you are using a one transformer unit. The C is for common and is usually blue in blue in the units I install.
The colors stand letters stand for
W - Heat
Y - AC (outside unit)
G - Fan
Thank you for choosing FixYa.com
Justin
Mar 13, 2011 | Honeywell Heating & Cooling
My M30CF AC unit is blinking green and red twice and then red by itself 3 times. then repeats. My air conditioner is shutting off randomly and doing this. Can you tell me what the problem is?
If you have the manual for your unit... look in the troubleshooting section and see what that combination of lights means... those lights are flashing a code at you telling you what is wrong...
When you get the explanation, then comment back and tell me... I may be able to help correct what is going on then....
BTW, did you try to recycle the power to see if it goes away???
heatman101
Nov 15, 2010 | Friedrich M30CF Split System Air...
Honda cb250w 1998 problem with regulator - not sure of the wiring details. Has three yellow wires , a green and a red/white. In Melbourne Australia
The three yellow wires are from the alternator and supply AC voltage. The green should go to earth. The red and white is the 12 volt DC that will go to the starter solenoid/battery connection.
Jan 30, 2010 | Honda CB 250 Motorcycles
My power lights keep going from red and green then they go off altogether. i have to fiddle around for a bit before the power comes back on mim 2120 medion laptop
Could be three things causing this. First, the DC jack soldered on the motherboard could be loose. Over time the solder will crack loose. Most likely this is the problem. Second, the AC adapter could be going bad. Finally, the battery could be going bad. Each of these items should be checked.
Nov 17, 2009 | Computers & Internet
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Three red lights come up when i turn my xbox 360 on
Hey dead end,
While this may be an indicator that something is wrong with your XBox 360, there are a couple of steps that you can take before seeking additional assistance.
According to information provided by the manufacturer, the light on your XBox 360's power supply should still light up green even when the console has encountered a three red light problem. If the light on the power supply isn't green, you will want to take different actions based on what color is displayed. If this light is red, the AC adaptor may either be defective or has recently overheated. If the light is orange, you may need to double-check all cable connections are secure. If the light on the AC adaptor isn't lit, the AC adaptor may need to be replaced.
Alternatively, you may want to try turning the XBox 360 off, then pressing the power button again roughly 10-15 seconds later. If the unit powers on normally and the three red lights disappear, the system may simply have needed to be reset.
Should the problem still persist, you may need to speak directly with Microsoft for further assistance. You can reach Microsoft's toll-free XBox support hotline at 800-4MY-XBOX (800-469-9269), or you can always request service through the XBox website:
http://www.xbox.com/en-US/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 24, 2008 | Video Game Consoles & Games
Hi..how to format ngage if its stuck up in nokia logo???
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
Disclaimer : I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
Good Luck.
Live, Love, Laugh.
Feb 18, 2008 | Nokia N-Gage Console
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
