Question about Mitsubishi WS-65809 65" Rear Projection Television
My sets power light comes on, blinks and then goes off immediately after about 2 seconds. I mashed menu input and got the following code...2 blinks followed by 4 blinks. Can you please tell me how to fix the set? My email address is tommybennett@hotmail.com. Thanks
  • tommybennett Nov 15, 2010
    Thanks for the prompt response. I have a tech friend, but have a follow up question. You mentioned "ICXXXX" and then there was a sentence break before the words "vertical chip". Is ICXXXX the name or number for the vertical chip I need to order, or can you give me the proper name or number, and an approximate cost to purchase this chip?
    Thanks
  • 10,515 Answers
This error means - 2 - 4 = Vertical protect (usually loss of vertical from the source)
The vertical circuit has to be trouble shot by an experience technician, This can be tricky for a novice,, It can be a bad vertical chip, or its source which is the E-prom, a meter and a scope may be required for this repair, If a family or friend member has technical background i would say the easiest thing to do would be to change the vertical chip and this may solve the issue, ICXXXX
vertical out put, But with out skills this failure should be done by a tech, And repairs for this unit should be under 200.00 and is worth it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2010
  • taran_2005
    taran_2005 Nov 15, 2010
    Thanks for your response!!
    CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE.
    LOCATED ON THE MAIN PCB.
    If you wish, you could buy the complete service manual from :-
    http://cgi.ebay.com/MITSUBISHI-WT-46809-...
    Hope i helped you.
Power supply isn't working
dOES SET COME ON WITH POWER LIGHT ON AND A FEW SECONDS LATER SHUTS OFF?
WHEN it turns off press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both.
watch for power light to blink a two digit error code like 1 blink, 2 blinks and then pause and repeat the code for about 5 times .
Let me know what code you find .
Dec 21, 2012 | Mitsubishi VS-70707 70" Rear Projection...
PPOwer Light comes on anfd goes off
It depends on what is wrong and you can narrow it down with the self check your set has.
If set has been unplugged--plug it in and turn it on--when green power light comes on and shortly after goes out----on the front of the set press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of five times.
2,2 is most common and most easy to fix.
Let me know what error code you find.
Jun 11, 2012 | Televison & Video
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I turn on my set and the power light comes on for 2-3 seconds then the set turns off. What causes this to happen?
F power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65411 65" Rear Projection...
Will not turn on after manually pressing on button power is connected
TWO QUESTIONS:
1.) DOES POWER LIGHT JUST BLINK?
2.) IF POWER LIGHT COMES ON FOR A SECOND OR TWO AND GOES OUT, do the self check this set has:
when light goes out press and hold both the menu and input (device) buttons at the same time on the front of the set for at least five seconds and release both.
Power light in this case will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will help you.
SD TECH
Nov 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
How do you perform the self check if the power doesn't come on?
if power light comes on and goes off. Press and hold both input and menu (input may be labeled device) on front of set for at least 5 seconds. Release both buttons and power light should blink a error code like 2 blinks, 2 blinks a pause and repeat it several times.
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Turns on then goes off immediately
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The green light on our mitsubishi tv WE-48511 turns green and turns on for about a second and then immediately turns off. The unit will not power up at all. any ideas?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(or input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 27, 2009 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
