Question about ACCO Brands Air Tools & Compressors
WE HAVE AN ATLAS CAPCO GA 15FF MODEL AIR COMPRESSOR.IT HAS A PROBLEM THAT IT SHOWS THAT MOTOR OVERLOAD PROBLEM AND SHD NC HOW IT CAN B OVERCOME
Compressor main motor was tripped intermitantly two, three times in a day.we have checked motor winding, ground,filters,and current also nominal. but fault not understood clearly. help me.
Posted on May 16, 2013
    Novelist:
  • 205 Answers
We need to try to find the problem by doing a little trouble shooting. First check the amp rateing on the motor name plate. Next check the amp setting on the motor overload. It should be set no more than 10% above the motor rating. While checking the overload setting check all of the starter and overload lugs/screws to make sure they are tight.Next lets check the amps on the the motor using an amp meter with the motor running and compressor fully loaded. Amps at full load should be within 10% of name plate rating. If Amps are high Check incoming voltage. If all of the above checks out you may have something internally happening in the airend.
Posted on Nov 15, 2010
We have atlas capco compressor ga 15 its temp so high 102c we changed oil filter oil separator air filter and oil but still its temp so high what can i do for it
1st ck to see that the internal cooling fan is running
2nd ck to see that air/oil heat exchanger is not plugged off with dust
3rd make sure machine has proper oil level as provided by sump level gauge , this should be ck'd while running as oil level will drop as machine is running .
if all these conditons are good , there can be only two other problems to cause this (1) outlet pressure setpoint too great
(2) air/oil heat exchanger has internal blockages
Dec 22, 2015 | Air Tools & Compressors
I have air compressor atlas copco GA 75 after i change the oil separator AT (8500HR) with 135hr was damage . i review all connection but i didn't reach the reason for this problem
possible cause is that minnim pressure imploded the separator due suddenly opening the valve on the discharge of the compressor so all internal pressure get released to quick and that what causes the separator to fail
Oct 29, 2014 | Air Tools & Compressors
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
ATLAS COPCO GA45+FF. COMPRESSOR SHOWING OVERLOAD MOTOR/FAN MOTOR. HOW CAN WE RESET
Could be the unloader valve did open, Unhook the motor from the compressor and see if you can turn the motor on, then see if the compressor can be turned by hand
Jun 13, 2013 | Air Tools & Compressors
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Air Tools & Compressors Logo
194 people viewed this question
Top ACCO Brands Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an ACCO Brands Air Tool and Compressor Expert? Answer questions, earn points and help others
