Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Badger 5 insink erator is leaking out of bottom. Is this a seal or something that can be replaced?
    Genius:
  • 1,015 Answers
If it is actually leaking from the bottom there is nothing you can do except replace it, there are no user servicable parts in the bottom end on disposal. I would carefully check around drain outlet and gasket where it mounts on bottom of sink. If it's leaking around drain outlet from disposal there is a replaceable gasket there or on underside of sink where disposal mounts. If you find that it is leaking from either of these locations I would be happy to instruct you on how to change them Hope this helps you, Thanks.
Posted on Nov 15, 2010
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a model 5-81 insink is leaking water out the bottom of motor is 1/2 h,p. what is the fix s/n 04065175183
Once disposal is leaking out the bottom, it is rusted out and needs replacement.
If you plug the leak, then water fills up inside the motor and unit shorts out.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My sink erator badger 5 is leaking at the bottom, should I replace it or try and stop the the leaking.
mine was leaking from bottom, dripping off power cord...pulled it apart..the pan that separates the water and food from the electric motor was developing pin holes from corrosion...I dont know that you can get this part...was thinking about tacking a small weld...but best off getting a new one...I am sure it has served...
Jan 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water drippinp from the bottom of badger 5
Check all of your seals. Wipe your hand all the way around your disposal to check for moisture running down. Pay close attention to the areas where there are seals, like the top where the main gasket is located and the side where your drain connects there are rubber gaskets that can begin to leak. Also check where the dishwasher drain connects if applicable. If all gasketed areas are ruled out than unit itself may be leaking and need to be replaced. I hope this helps.
May 26, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator leaking at bottom by electrical connection
I don't think it can be fixed by anyone other than the factory. I wanted to find a parts list so I could buy a seal that goes above the motor housing (which is where i think the problem really is) and repair it myself. I wish I had better news but since the leak is small and the motor still works, I'm going to keep a bucket beneath it and periodically empty it as recommended by a previous contributor.
May 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
534 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
