Question about Alpine CDA-9813 CD Player
Unit turns on and off by itself while driving. This started after I had the car on jack stands for a couple of weeks and I had left a CD in the player. I have no idea if the "on-off" problem could rationally be related to the car being on jack stands, but perhaps leaving a disk in the unit caused the mishap.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Try cleaning the contacts on the back of the face and the subpanel, you can do this with qtips and rubbing alcohol or a pencil eraser.
Posted on Nov 15, 2010
How do I check for worn wheel bearings
lift vechiel and support by jack stand. grab top and bottom of tire and wiggle it in and out, alternatly. or up and down, depending on how you look at it. but easiest way is to drive it. when noise happens, turn left and right, if noise gets louder or quieter as you turn then its guareenteed to be a wheel bearing. turn left and get louder, replace right side. if turn right and gets louder replace left side. if noise does not change due to turning. then not wheel bearing making noise.
Sep 12, 2014 | 2005 Ford Explorer
I want to hook up my CD-BA2100 to my Inspiron 6000 laptop but i don't know how to hook it up or what to use.
The SHARP CD-BA2100 is a "stand-alone" cassette/CD/AM/FM player.
Its manual states that it can accept left/right stereo audio output, such as from your laptop, if you purchase the correct adapter cable (from "line-out" or "head-phones-out" on your laptop):
Video/Auxiliary (Audio signal) input
To listen to or record signals from external sources through this unit:
1 Use a separately available RCA cord to connect the desired external unit to the VIDEO/AUX jacks. (red ® right channel, white ® left channel) * When using video equipment (Laser Disc player or VCR), be sure to connect the audio output to this unit, and the video output to a television.
2 Press the ON/STAND-BY button to turn the power on.
3 Press the VIDEO/AUX button.
4 Operate the external unit.
5 To record the sound from the external unit ...
i.e., you can use it as the speakers for your laptop, instead of the laptop's tiny, built-in, speakers.
Mar 31, 2011 | Computers & Internet
Power steering is hard to turn at times, fluid is full, is there a belt other then the serpintine??? i dont see one on the power steering pump
does it make noise when turning ? when installing new power steering pump with both front tires in air on jack stands or jacks start and fully steer right fully steer left repeat a couple times and shut off now pump is bled place on ground and test....by turning take a drive....
Mar 19, 2011 | 2002 Dodge Stratus
How hard is it to replace a automatic transmission in a 93 Grand Cherokee Laredo with a 5.2L-318 cubic inch engine.
Working standing up, with the proper adjustable transmission jack and air tools, I've seen good techs do a complete R&R in less than a half day. Working on the ground, lying underneath, using hand tools, you run into clearance problems, balance problems (the unit is relatively large and difficult to get into position). Using muscle instead of the proper jack often results in bent flywheels, damaged sensors or worse. In using a reliable shop to do the work, unless you are installing a used unit, you have a guarantee (used units are guaranteed but the shop will charge each time the unit needs to be removed if you get a bad one). That in itself is a "game changer". Unfortunately, the cost of a rebuilt unit, including install is likely higher than the book value of the vehicle. That's why you see many GC's for sale cheap, all with trans problems.
Can a novice do the job? Yes, but you will take anywhere from two to four days doing it. Get a chilton or haynes manual to guide you through the job, work on a flat hard surface (cement slab or at the least, a couple of sheets of plywood so you can move the jack) and try to rent a ground level trans jack. Always support the vehicle on good solid jack stands. If installed carefully, the only worry would be the quality of the unit you install.
Good Luck!!
Dec 03, 2010 | 1993 Jeep Grand Cherokee
My truck makes a loud noise in the left front when i turn left and the abs light goes on when i turn also.
sounds like the hub bearing
jack the truck up and grab the tire at the top and bottom and push in and out there will be one that is very loose that will be the problem
Nov 06, 2009 | 2006 Chevrolet Silverado 1500HD
I have a humming noise I the front end. I've jacked the car and there is no play in either of my wheels. The noise starts around 25 mph and gets deafing loud at 65mph, however it seems to go away around...
It sounds like you could have a problem with your wheel bearings.Wheel bearings do not have to feel loose to be noisy .A way to check would be to jack the front wheel off the ground.Support the front with jack stands under the lower control arms.Have someone drive the car with the wheels in the air and use a stethescope to listen for noise at the front bearings.
Note that feathering of the tires can also cause the noise.Feel for sharp edges on the inside or outside of your tires.
Oct 17, 2009 | 1997 Ford Taurus
Pull to the left
This could actually be several things. Start with the simple stuff like checking tire pressure. If that is fine, then jack the front end of the vehicle up, and put it on jack stands and with the car in neutral see if one of the front wheels is harder to turn than the other. If this is the case, you could have one of the brakes dragging, and will need to fixed. If this does not help, take it in for an alignment. They will typically do a free inspection of all steering/suspension components.
Chris
Mar 26, 2009 | 1998 Mitsubishi Diamante
Alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Nov 25, 2008 | Alpine CDE-9852 CD Player
TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Dec 28, 2007 | Teac CD-X9 Shelf System
Alpine CDA-9813 CD Player Logo
162 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
