Question about Compaq Computers & Internet
HI.my computer woorks good till i let it stand for a short time then it locks up.please help.i have windows xp
    Brigadier General:
  • 10,406 Answers
> then it locks up
Can you give more detail?
Is it overheating? Are the fans inside the desktop working correctly?
Posted on Nov 15, 2010
I'm Becky D. I'm having trouble with a friends tablet.it will turn on but, it will not do anything else, it stays at first page, which is the time and lock page. How do I fix it?
Hi. Try to do backup or start last good configuration:
To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER.
Feb 21, 2015 | Proscan 7-Inch Android Internet Tablet,...
I am trying to run Digimax Master on my Windows 7 Op System (just upgraded from XP Home) - appears to be incompatible?
Hi, I would like to help you out. You are absolutely right about this compatibility issues. But don worry there is always a solution.
You can make these applications believe that it is running in windows XP. Just follow these simple steps:
* click on start > control panel > programs and features > select "run programs made for previous versions of windows"
* just keep clicking "next" till the you can see the list of applications to choose.
*then select the "try recommended settings". and go on till you finish it.
I'm sure you will do it right! :) This will surely fix the issue for you.
Please let me know if you need more help. Good luck
And also vote if you think this solution will help others. Thank you:)
Oct 26, 2010 | Samsung Computers & Internet
My acer laptop doesn't continue after setup configuration
try to install again windows xp this time boot cd first and then format your C drive and then install.
Oct 23, 2009 | Acer TravelMate 4150LCi Notebook
Xp [problem
bios setting can be seen before booting .When computer starts start pressing "Del" button or in some pc need to press f1 or f2. Then in bios setting u will see hardware setting.IN that option hdd drive setting is present. After that save setting and start booting. If then not works then default all the setting of the bios and try.
Aug 04, 2009 | Compaq Presario Notebook
My computer is denying the password
It states that you are using XP Pro. if you are locked out of your system by entering the incorrect password too many times, you have only a couple of choices short of re-installing XP Pro.
1.Did you make a Password Disk? If so problem solved, just insert the disk and it will open up.
In the event there is NO Password disk, you will need to locate special software to be able to unlock your computer. This software can be quite expensive at times.
OR, you can Re-Install your Windows XP Pro, and LOOSE everything on your hard drive in the process. Hope you Back-Up often to offsite/External source.
Good Luck, Oh check your CAP lock key, the biggest mistake made when entering passwords.
May 10, 2009 | Microsoft Windows XP Professional for PC
Can I expect any problems with installing Windows XP Service Pack
Short answer is yes. You'll stand a better chance of sucess if you download it from the windows update site. Also, go to your computer manufacturer's support website and check your model for any software upgrades that may be needed before installing sp3.
Jan 26, 2009 | Computers & Internet
My desktop icons are written clear but under colour
If you are running XP, click Start > Programs > Accessories > System Tools > System Restore.
Follow the prompts and select a bold date back to a time earlier than this problem occurred. It will require a reboot, but stands a good chance of resolving your issue.
It will not remove anything from your computer, but you may have to re-install any software recently installed.
If you get it fixed and then re-install some software, the problem may come back. That would let you know the software is causing the problem.
Honest1abe
Dec 29, 2008 | Microsoft Windows XP Professional for PC
Media center problem please help!
http://support.microsoft.com/kb/895678/en-us ,http://support.microsoft.com/kb/887213/en-us, http://support.microsoft.com/search/default.aspx?catalog=LCID%3D1033&query=window+media+center&mode=r , try these sites and if these dont fix the problem then get back to me and i will not quit till you are back to haveing a pleasant computer experiance. good luck.
Oct 19, 2008 | Microsoft Windows XP Media Center Edition...
NF-M2S restarts.
Hi! Hope this helps. Please consider other components or cards installed on your motherboard. Please try removing one at a time then have it start and shutdown if it works. For harddisk management please see the power management at control panel, select the how or when you are goin' to set your harddrive sleep, standby, etc.. We had also met "Standby Mode Problem", by cleaning viruses, spywares and even the registry it can be fixed. Please search for the right and specific tools. Goodluck!
May 28, 2008 | Abit NF-M2S Motherboard
Toshiba A35s159 windows XP going auto-off !
I think Ur laptop have Viruses.Please format hard disk and reinstall windows.
Feb 25, 2008 | Toshiba Satellite A35-S159 Notebook
Computers & Internet Logo
12 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
