Question about Fujitsu LifeBook A3110 Notebook
Fujitsu Lifebook A3110 won't boot from Vista DVD but will boot from Windows 2000 CD. The boot order is set correctly in the BIOS. When I insert either a Windows XP boot disk or a Windows Vista boot disk it won't boot. I have tried both of these OS boot disks on other computers and they work fine. The Windows 2000 boot disk works with no problem. I've flashed the BIOS and even replaced the drive. Same issue remains.
  • 1 more comment
  • vopro1 Nov 15, 2010
    Thanks for your speedy reply. I don't have a USB drive that big at the moment. I would have to go purchase one. On a separate note I was able to load my Vista OS using a friends external USB drive so at least I got that far. The problem I'm faced with now is I have an extra optical drive I paid $50 for and I don't know if it's a bad drive or not. It just seems weird I can watch a movie from a DVD on it but it won't boot from a DVD but it boots from the Windows 2000 CD. I also tried putting in a DVD which I burned Windows AIK to and it won't read that either. Is there any possibility there is something in the laptop BIOS that won't recognize bootable DVDs even though it recognizes a regular movie DVD?
    Thanks, I will wait for your reply.
  • Anonymous Mar 26, 2014
    Constantly boots up windows error recovery, does not boot up from recovery disk just reloads same error problem, changed all settings to try and boot up from disk still doesn't do it. Tried BIOS settings and diagnostics but they don't provide much help. Any suggestions would be great! Worked fine until laptop cut out earlier and now wont load
  • Fujitsu Master
  • 13,433 Answers
Can you get the machine to boot up from a USB stick? create a bootable usb stick with instructions below and transfer everything from the DVD to the stick. you need around 4GB stick.
On another machine, open the cmd.exe or command prompt with administrator rights.
In the prompt write diskpart and hit enter.
Then type list disk, note the disk number of the flash drive.
lets say your pendrive is disk 3 (replace it with your own number)
Then enter the following commands in diskpart and hit enter
Select Disk 3
Clean
create partition primary
select partition 1
active
format fs=ntfs
assign
exit
Next insert your windows disc in the drive, find out what is the drive letter of your dvd drive and what is the drive letter of your usb stick then go back to the command prompt
Enter the drive letter of your dvd drive and hit enter like this for example if it was D drive then below (and don't forget" : " without the quotes)
D:
Next enter CD BOOT
write bootsect.exe /nt60 F: ((Where the F is your USB Sticks Drive letter))
Copy the DVD content into the usb stick by using the normal explorer, no need to do that on the command prompt.
Change your laptops boot order so it boots from USB-HDD or USB-XXX (replace XXX with any other available usb option...) Hopefully this does it.
Posted on Nov 15, 2010
  • 1 more comment
  • Ekse Nov 15, 2010
    If the drive plays DVD's and CD's its fine.
    But I'll check with a colleague that works at Fujitsu repair and see what he says about it.
    I can't reach him right now, I'll probably hear from him tomorrow.
  • Ekse Nov 15, 2010
    will get back to you as soon as I hear anything.
  • Ekse Nov 16, 2010
    I remember we used to install these fujitsu machines off usb sticks, but it probably was mainly due to not having a vista dvd's around.
    The friend is a friend of a friend, I heard he hasn't worked for Fujitsu in almost a year now, and he might not remember anymore.
    I'm pretty sure your both drives are OK.
    Will get back to you when I hear something from him.
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
Although I have excellent connectivity when I try to open Internet browser I just get a blank page and Internet cannot connect message. So I want to restore to factory settings and reinstall Vista...
You should go to the BIOS. Make a note of the boot order. Set the first boot device to cdrom.
Once you see a prompt that says press any key to contintue to boot to cd press the Enter Key Once
When you have a prompt that says welcome to windows press R to Repair press F3 to quit and press Enter to create a fresh new copy of windows.
Follow any prompts as required and when you have finished don't forget to change the BIOS boot order, back to as it was.
There you have it, a fresh operating system. All it may need now is the drivers installing and the software re installing.
I hope this is the information that you require.
Nov 20, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
Fujitsu Lifebook N6470 will not boot
Most times these kinda errors are issue with some kinda corrupted driver. Have you tired to boot in to safe mode. To do so shut down the laptop and when you press power to turn it on start tapping F8 key until advanced windows start up shows up.If you cant i would consider taking it back to store where you got it since pressing this button is not supposed to do anything. Most new computers come with Operating System reinstall built in which kinda sucks since some times you just cant get to it like in your case. Restore disk shoud work and you can try making Bios settings back to original since Vista will boot to the CD/DVD drive if it detects media. If this does not work i would not spend too much time on it and would replace it or have it fixed if you have extended warranty. I would also be very careful about posting Product key on any web sites. Hope this helps.
Jan 13, 2010 | Fujitsu LifeBook N6470 Notebook
FUJITSU LIFEBOOK N3530, INTEL CENTRINO DUO. THIS LAPTOP WILL GO THRU THE WHOLE 9 YARDS OF REFORMATTING AND INSTALLING BOOT FILES FROM FLOPPYS,WINDOWS XP, WINDOWS VISTA. BUT WHEN IT COMES TIME TO BOOT UP IT...
check the BIOS...
check the boot sequence in bios...
may be it's not set to boot from HD....
pls let me know if u can make changes in BIOS and can set HDD booting...
i will explain how to do it if u need...
have u formated and reinstalled windows...?
let me know more details pls...
Dec 20, 2009 | Fujitsu LifeBook N3530 Notebook
My Lifebook C2340 won't recognize it's own DVD-ROM. When I set the CD in the BIOS, it goes back to "None". It doesn't show up in My Computer. I've cleaned the contacts and tried another DVD. Still won't...
Does it show the device in the BIOS? If not then there could be a problem with the motherboard hardware. If it is not showing up in the BIOS then I would first verify that the power connector for the drive has voltage. Also verify that the slave/master jumpers are correct if the drive has any. You could also try downloading the BIOS update from Fujitsu and see if after updating the BIOS it brings the cd-rom drive detection back. If the BIOS is seeing the drive but Windows is not then the problem could be with the Windows drivers or installation. You could try going into the control panel for windows and use the "detect new hardware function" and see if Windows detects the drive.
Dec 16, 2009 | Fujitsu LifeBook C2340 Notebook
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
I have a Fujitsu Lifebook P-2040 that I just reformatted. I'm going to install Windows 2K Professional (don't have the restore disks for XP Home). After I reformatted and restarted, nothing happens. There...
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Dec 20, 2008 | Fujitsu LifeBook P2040 Notebook
Fujitsu U810 problem ( not booting )
that means that you need to repair it in order to get the laptop back to its normal condition insert windows xp disc and repair the system that's what i think
Nov 28, 2008 | Fujitsu LifeBook U810 Mini-Notebook ...
Fujitsu LifeBook A3110 Notebook Logo
228 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
