Question about Conexant v.92/v.90 PCI Data/Fax Modem (MDMV92)
Frequently modem shuts down for no particular reason and must be restarted by turnig power off and on repeatedly. Ethernet a nd internet lights go off when this happens.
  • 516 Answers
If you are using dsl or faster connection, you don't need your modem anymore. Your computer works fine if you unplug the modem. Except if you still using dial up connection, so in that case buy a new modem.
Posted on Nov 15, 2010
I have cable internet and how would i connect the DGL-4500 wireless router to cable???
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the network-port on the cable-modem to the 'WAN' or 'Internet' port on the router.
Use another Ethernet cable to connect the network-port on your computer to one of the 4 'LAN' ports on the router.
Turn the cable-modem on.
Wait for its lights to settle-down to a repeatable pattern.
Turn the router on.
On your computer, you should have Internet access.
Feb 21, 2011 | D-Link DGL-4500 Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
No modem recognition, lights appear alternately then repeats.
1. Unplug the router for 1 minute then plug it back to the power and try you connection.
2. check with your ISP to see if you have proper connectivity with them.
3. if so, go through the basic setup for you router
4. check the manufacturer site to see if you have firmware updates or if the router has come to what is call "end of life" and is no longer supported.
May 22, 2010 | NetGear WGR614 Wireless Router
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
Jun 06, 2008 | Arris Touchstone 450a (CM450) Modem
Conexant v.92/v.90 PCI Data/Fax Modem (MDMV92) Logo
74 people viewed this question
Top Conexant Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Steve
Tarpan Shrivastava
Tarpan Shrivastava
Are you a Conexant Computer and Internet Expert? Answer questions, earn points and help others
