Question about Ricoh Aficio CL3500N Laser Printer
Aficio cl3500n error code SC411, the printer comes up with a error code, all button function locked
    Sergeant:
  • 260 Answers
I remember a discussion on this code in an old thread somewhere. The agreed solution was to replace the whole transfer roller assembly because of a broken contact terminal in the discharge plate housing. I'd probably try that before a high-voltage board.3
For more help visit cbr tech solutions
Posted on Nov 23, 2015
  • 3 Answers
SOURCE: Service manual.
Our service manual came in a disc form. Our operating manual has an address & phone number contact. This might help, I don't know. Here it is:
RICOH CORPORATION
5 Dedrick Place
West Caldwell, New Jersey 07006
Phone: 1-973-882-2000
Posted on Apr 14, 2008
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 9 Answers
SOURCE: Aficio CL3500N Photo Conductor Unit
If your print outs are clear and the PCU is surely new.
Press Menu
Scroll to Maintenance <Press Enter>
Scroll to Replacmnt Alert <Press Enter>\
Scroll to PCU <Press Enter>
Select Notify Later <Press Enter>
Good luck.
Posted on Apr 06, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
SOURCE: printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Ricoh aficio 2550 code error SC411
Ricoh Aficio 250 Error Codes
Code
SC411
Description
Separation bias error
A separation bias leak signal is detected.
Causes
• High voltage supply board defective • Poor connection of the PCU • Discharge brush defective
Apr 10, 2017 | Ricoh Office Equipment & Supplies
My printer Ricoh aficio cl3500n does not print and all the lights on. Why?
The first step is to turn the machine off and then turn it back on. Do all the lights come right back on, or is it okay until you try to print to it?
If all the lights are on, there should be an error message appearing on the display. It might say out of paper, or out of toner, or a cover open, or it might show a code (such as "sc 501").
What is the code or error message that appears?
Jul 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Error code SC471
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
May 05, 2010 | Ricoh Aficio CL3500N Laser Printer
Error 441 Ricoh Aficio CL3500N Laser printer... what should I do?
Hi
It is EVELOPER MOTOT LOCKED.
I can only gave you a link to look at but it only have the error codes.
http://grou.ps/www_diycopymachines_com/talks/20700
Feb 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 4506 error code sc422
SC411 Separation bias error SC422 Main motor lock
Jan 15, 2010 | Office Equipment & Supplies
I get an error code of SC 411 it says to power off the machine.
That is a color pcu motor error. I would try replacing the color pcu unit first. One of the waste toner augers has backed up with toner causing everything to lock up.
Jul 30, 2009 | Ricoh Aficio CL3500N Laser Printer
Error SC 411 appears
SC411: Separation bias error
-Definition- [B] A separation bias leak signal is detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Discharge brush defective You need the service manual or have a technician fix it. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 15, 2009 | Ricoh (R) Aficio CL3000 Color Laser...
Error message replace/ supply
If you open an internet connection and an the top address bar type in the IP address you will see you printer and be able to see the supply that needs changing
Jan 05, 2009 | Ricoh Aficio CL3500N Laser Printer
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
180 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
