Question about RCA RT2390 System
Menu button on RCA rt2390 does not work need to access to change to digital hookup
2 Suggested Answers
dave1645
  • 834 Answers
SOURCE: Cannot access setup!!
make sure you are in the tv mode first or you will not be able to access the setup mode and make sure you run setup
Posted on Sep 22, 2009
Can i use the RCA subwoofer output jack?
The subwoofer jack might be switched off. Have a look under the menu of the system to see if it is off.
Apr 29, 2016 | RCA RT2390 System
I have a rca rt2390 iam only hooking up the tuner what antenna do I need and do I have to have the am antenna all im getting is static
are you using a signal converter between antenna and the set .new digital signals require it with older sets
Jan 21, 2015 | RCA Televison & Video
Optical audio doesnt seem to work... Does it need to be turned on and if so how do i do that?
put source on SAT. use the remote and hit "set up" use right arrow button until the word "coax" shows on unit, Now your digital.
Good Luck
Oct 14, 2010 | RCA RT2390 System
Sep 22, 2009 | RCA L37WD12 37 in. LCD HDTV
Optical cable is pluged in but the unit wont recognize it.
the problem is that you need to select the source on the remote of the unit and then select setup, you will be able to change the source from analog to digital (i don't remember the setting) and voila! it should work
Jul 30, 2009 | RCA RT2390 System
Rca rt2390 lost remote 5 years later lost electricity reciever reset and no optical input designated cannot designate optical to input source without remote...help
I found somewhere called newremotecontrol.com they have the remote for less then $20 bucks ... I lost my remote 3 years ago
Feb 19, 2009 | RCA RT2390 System
Reading rca cables
Hi!
There is obviously a lot of background that is missing form your question, most specifically the kinds of equipment that you are using and the exact way that you have wired the components. However, I can tell you that a common problem when changing the "source" for DVD/VCR units is to also change the source settings inside the unit, which are usually accessed through the setup utility, which is usually in the menu of the DVD/VCR. To access the menu, you may have to have the coax cables hooked up, just until you change the settings to the RCA (component) cables.
Good luck, and let me know if this helps!
Bob
Oct 07, 2008 | Sanyo DVW-7200 DVD/VCR
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
RCA RT2390 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
