Question about Motorola Mobility MOTORAZR maxx V6 Cellular Phone
REplacing the front glass lens
We have cracked the front glass lens on our V6 (seems to be a very common problem from the posts i read on different sites). We have a new screen, but cannot get the old one off. Any suggestions?
thanx
Jody
  • kaston12 Jun 19, 2008
    I already have a new screen, but the existing cracked one is proving difficult to remove. We understand the warranty implications but wish to go ahead ourselves.
    thanx
    jody
    Genius:
  • 2,035 Answers
Its difficult to open manually and could lead to malfunction of the phone , you need to go the nearest local mobile service center get it fixed in as you the new screen it wont cost you more, TO remove the screen you need to have special tools which will cost you more........
Posted on Jun 19, 2008
  • 13,433 Answers
You would basicly need a service manual to figure it out without breaking anything.
    Guru:
  • 1,894 Answers
Replacing the screen is not a small job.
u need to have a good experience in electronics.
and so u will have to open the planed to go and replace the screen.
  • 1 more comment
  • dewan nafees ahmed Jun 19, 2008
    If its just the glass rather than screen itself then its literally a 2 minute job - peel old screen off then stick new one on
    all you have to do is take off is that front metal
    faceplate 4 screws under the rubber stoppers and pop it off gently with
    a plastic tool, then peel the old glass, being careful to keep it
    clean, snap the faceplate back on so you can align the new glass and
    stick the new glass in.
    this is what u asked for
    thank you
    don't forget to accept the solution if u go by it,
    good luck
    have a great day
    http://cnn.cn/shop/motorola-razr-maxx-c-...
    this can be of very much help for u.
    any comments about my solution?
    i have said u how to remove that old one.
    President:
  • 2,712 Answers
What do you mean? you want a new screen? You will have to contact a service place..
  • Swilin Sampson
    Swilin Sampson Jun 19, 2008
    Not too difficult to get it off, but if you want your warrantee, go to a repair shop.
How to remove the front flasher bulb ?
gently remove the screws holding the lens in place
remove lens and gasket set aside
firmly grasp the glass of the bulb, push, and twist until it will not twist any more
it should pull right out
replace in the same manner you removed it but be very careful when replacing the gasket to not pinch it or have it misaligned because this will led to corrosion, and do not over tighten the screws for the lens, this will crack or break the lens.
Aug 04, 2015 | 1996 Yamaha Royal Star XVZ 1300 A
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
The glass on my 18-200 lens was cracked on the very edge of the lens. I was wondering how expensive is it to replace the glass?
hi there...
so sorry to hear that your lens was cracked...
the reparation will costs you expensive enough, and i suggest you buy a new one
if the lens still working, you still can use it taking pictures, but the picture will need some correction using photoshop or any other graphic software
thanks
Jan 11, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Lens got dropped and the out glass cracked. Lens
Hi, there.
I assume you mean the 77mm FILTER that was screwed on the lens.
Apr 25, 2010 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
The lens cracked. The camera still works but the picture shows cracks. Is it possible to repair it?
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
Jul 12, 2009 | Pure Digital Flip Video Ultra Camcorder
I have an antiqe spyglass
a lot of those old scopes eventually had cracks in the objective lense..trouble is the focal leght of the objective is hard to match and i dont think you will. it was two pieces of glass a double convex and a plano concave with airspace.sorry for the bad news.....larry@reichinstruments .com
Nov 19, 2008 | Optics
Newcon Optik Stargate M Problem
There is no point in addressing queries to individuals, as they may no longer be able to assist. Your best option is to post the entire details of your query, so that anyone with the appropriate skill and expertise can endeavour to help you.
Aug 02, 2017 | Optics
Broken glass on the lens
Are you kidding? A camera lens are a group of various lenses inside. I don't think it's repairable, but I'd say take it to a local photography store and you can get free advice. I think I understood you, but anyone would have to see the damage in person. From here, I'd say you are in bad luck...it's a goner. Also cameras are not designed to take a big fall like that. There is probably more damage than just the lenses.
Apr 04, 2008 | Sanyo VPC-CG65 Camcorder
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
Motorola Mobility MOTORAZR maxx V6 Cellular Phone Logo
99 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
