Question about Weiser Lock Powerbolt 1000 Lock
I programmed the lock. It locks as it should, but does not respond to the programmed security code to open.
  • 963 Answers
Troubleshooting:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Also, check the jumper in your lock-you may have it in the wrong position for the way your door swings open (handedness of the door)
Posted on Nov 08, 2011
I need to know how to program remote
To program a new remote to the system; open door, turn ignition on, press and release valet switch one time then, press and hold valet switch. System will respond with a chirp. Now press lock button on remote. System will respond with a long chirp.Turn ignition off. Test system. Repeat for additional remotes.
Sep 28, 2012 | Dei 7641v Responder Remote 160xvl 7641
Will not lock or unlock doors
Does the unit respond when you press the unlock button, i.e., two chirps from the siren and/or parking lights flashing? If so, then the door lock wires are no longer connected or, there is an issue with the vehicle's door lock actuators.
If the Viper system does not respond with the above mentioned sounds and lights, then the remote is not programmed to system.
To program: turn the ignition on, press and release the valet switch one time then, press and hold the valet switch. While holding the switch, press the lock button on the remote. The system should respond with a long chirp from the siren.
Sep 07, 2012 | 7141V 4Button Remote
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
I held the black button down untill it beeped and then reset the entry codes (they were compromised). Since then it beeps after an unlock code is entered, then it beeps a few times and will not respond to...
ok -- so you know about the black re-set button ( that saves me some time ),,
1. push and hold the black button untill it beeps 3 times -
2. enter your new code,, 4 to 8 digits and then press the 'LOCK' button.
it should now be programmed to your new code.
now if you want to add more codes to the lock -- just push the black button twice and enter next code and hit the ' LOCK ' button,,, this will store the next code.
make sure you test the lock several times so you do not get locked out.
also -- change your battery once or twice a year ( depending on use ) to be sure it never dies.
now the reason it does not respond to button function is because it goes into lock down mode after about 3 tries,, this is a security function of the lock,,, before you try the re-program - let the lock sit idle for 5 minutes or so,, also just to make sure the lock does not get over excited - remove the battery and let sit for a few more minutes,, ( this is just a extra step that I do out in the field whenever I encounter this problem ) --- and yes I am a locksmith.
best of luck to you,, if you have anymore troubles - please write me back here and I will do my best to walk you through it.
have a great night,
c...
Feb 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
When we lock the door you just have to press the schlage lever on the top of the elecronic keypad and the door opens. Help we don't want to go to bed with the house unlocked
the lock is set in factory mode and needs to be programed to the security code that you choose.
go through the code set up and program in your code and the lock will work as intended.
if there is a problem with the lock and it will not accept the codes then the only way to disable the motor function of the lock is to remove the battery itself and use the key bypass until you can get the lock fixed or replaced.
c...
Jan 21, 2011 | Schlage Lock BE365VCAM716 Electronic...
Keyless remote wont work
try to reprogram the remotes using these instructions..........
i assume for 02 explorer not th 05 frestyle listed (although similar procedure)
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Make sure that the anti-theft system is not armed or triggered and key code programming is not active.
  1. Open the door, then press the driver door lock control switch UNLOCK button.
  1. Turn the key from OFF to ON 8 times within 10 seconds, with the eighth turn ending in ON. If the program mode is sucessfully entered the doors will lock and unlock to confirm.
  1. Press any button on a remote transmitter, and the doors will lock and then unlock all doors to confirm that the remote transmitter is programmed. All remote transmitters must be programmed within 20 seconds of each other. Up to four remote transmitters can be programmed to the vehicles security module each time programming mode is entered.
  1. If the door locks do not respond for any remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Locks, Latches and Entry Systems — Late Build or Locks, Latches and Entry Systems — Early Build in this section.
  1. NOTE: Exiting is acknowledged by locking and unlocking the doors if at least one remote transmitter has been programmed.
    Exiting the programming mode is accomplished if one of the following has occurred:
    • The key transitions to OFF.
    • 20 seconds have passed since entering programming mode or since the last remote transmitter was programmed.
    • Four remote transmitters have been programmed.
Jun 02, 2009 | 2005 Ford Freestyle
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Keyless entry remote
Try this, it works on several 2002 models:
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Jun 20, 2008 | 2002 Mazda Protege
Weiser Lock Powerbolt 1000 Lock Logo
63 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
