Question about Jazz DV-179 Digital Camera
Video I can't read my video on my pc. they are to fast like 2 times the good speed,
  • 90 Answers
Please call custiomer service for Jazz products at 732-572-7050
Posted on Jun 30, 2008
Poor video on skype
use fast internet connection for video quality you need a good quality web cam
Jan 16, 2013 | Samsung Computers & Internet
I have recently bought a Hitachi DZHV595E camcorder and have upgardedd the memeory card to a Sandisk HDSC (Extreme HD) 8GB class 10, the camcorder doesnt appear to be seeing the card. When I put the card...
Hi i have a Hitachi DZHV595E HD Camcorderand when im videoing and pause it and take it of pause carry on videoing and look bout on the video it speeds fast then slows down then fast again please help as im
disappointed thanks james
Jul 26, 2011 | Hitachi Video Cameras
Engine idle speed too fast some times. idle speed
Three things to check for:
1) High idle switch is on..*(vehicle thinks AC is running but it isn't.
You can try turning on the AC and see if the engine slows down to confirm this one.
2) Sticking or worn out Idle Air Control or IAC, You might get a check engine light with this one.....you might not if it's a mechanical failure.
3) Simplest of all. A vacuum leak. You can get the engine vacuum read while running if you go to a mechanic with a vacuum guage or an OBD 2 ecu code reader. There should be specs on what vacuum levels are normal for you car at idle.
Good luck and be careful!
Dec 29, 2009 | 1996 Isuzu Trooper
Does processor speed affect the way your webcam works My webcam is not very REAL TIME it is very slow. MY processsor is old....2.80 ghz and I have 1.18gb of ram. Is this not sufficient?
Hello Flecia, hi;
The processor speed do someway affect the speed of your webcam, but the most common reason why webcam gets so slow is the program that shows the video. Skype has good quality videos, depending also on the speed of your internet connection and the graphics card installed on your PC.
Check also for computer viruses, these programs and malwares slows the PC down. Well a clean PC is fast enough, check also your hard drive, you may need to defrag it every month. Your Ram is sufficient enough, and your processor being a 2.8 ghz is still fast.
So here are the things you may need to do.
  1. Defrag your hard drive every month. or better, reformat your PC every 6 months to a year.
  2. Check for computer viruses and malwares.
  3. Install Skype (which I recommend) for your webcam online software.
  4. Get a fast Internet connection (if you are willing), atleast DSL minimum is 512KBPS.
  5. Get also a high resolution webcam. (if possible)
hope this helps.
Nov 21, 2009 | Computers & Internet
MY xbox 360 will read dvds but when i enter a game it goes to the disc error screen
Have you tried to get this system flashed?
What's happening is .. which could be a couple of things..
1.) Your Firmware board on your ODD Drive is telling the Drive to spin at a certain speed. The speed its currently spinning at is too slow to read a game, but fast enough to read a DVD disc.
2.) This could also be a motor or laser issue.
I would suggest sending it in for repair. There is nothing you can do without opening it to fix it.
Apr 14, 2009 | Video Game Consoles & Games
Delicate cycle works fine, other 2 cycles will fill but will not agitate or spin
It's probably the motor. Most times, the motor has separate windings for slow and fast speed. Before spending $120. 00 on a motor, I'd get a $5.00 voltmeter to confirm this. You can use the tech sheet to find which terminals on the motor are the fast speed windings, and check the resistance. Be sure to unplug the motor plug first. It should read about 8 to 14 ohms.
If the motor is good, the timer is the next likely candidate. Withoput knowing which machine you have, this is the best I can do.
Mar 10, 2008 | Washing Machines
Only delicate cycle work correctly, the other 2 cycles will fill but not agitate or spin, timer cycles o.k
Will not eject and reads hello on the front
your dvd burner is bad i went through 5 my self took them all back to wal-mart the 6th one i bought was a display and it whent out a week later so i kept it and replaced the dvd recorder . there is not enough air inside to keep it cool .if you have a dvd recorder that comes with a pc thats 16 speed dual layer the reason i said dual layer is because my fast foward frozze up on mine when pushing fast forward had to restart it if you have a spare one laying around i would try it. it hooks up like a pc, one strap and power wire i put a regular 16 speed single frozze unit up a 4, 8 & 20 speed will not work there ethier 2 fast or 2 slow you can pick up a internal one on-line that go's to a pc will work somewhere from 20 to $40 but i whould put it on top of the ilo because if you put it back inside it will burn it up to i don't know if you can even get one like was in it if you do it will probly cosat you more and i don't think there as goog as the pc one the one i replaced has lasted loner then all six of mine sorry my writing is so bad been a long time since scool if you have any qustions e-mail me at rjp6850@msn.com
Mar 03, 2008 | iLO DVDR04
Jazz DV-179 Digital Camera Logo
15 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
