Question about Gateway 310 S PC Desktop
Red light on motherboard 310 gateway computer
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Monitors wont work
It appears that you have a faulty graphics card.
If the graphics card is integrated with the motherboard then it cannot be repaired. Just purchase a new AGP graphics card, insert it into the AGP slot and connect your monitor to this card.
You may need to go to the BIOS setup to disable the on-board graphics card.
If you don't have an integrated graphics card, then buy a replacement graphics card.
You will need to install the new graphics drivers after installing the graphics card.
Posted on Nov 13, 2008
SOURCE: BAD MOTHERBOARD ECS MCP61P-AM Motherboard
You can. Just make sure it's compatible with the same processor, RAM etc...or it may cost you more in the long run.
You can bring that spec into the local computer store, ask them to just either replace or upgrade...make sure you tell them you'd like to use the same processor, RAM etc.
I hope that helps.
Posted on Jul 09, 2009
  • 194 Answers
SOURCE: gateway computer 310 series wont power up when
It sounds to me like the power switch is plugged into the motherboard incorrectly. I would need to know the type of motherboard you have to get you the proper schematic for hooking up the power switch and reset switch to the board. If you have the manual to the motherboard, there should be a detailed picture showing you how it is to be hooked up. Please let me know the motherboard model for further assistance.
Good Luck,
NOLA Tech
Posted on Jan 29, 2010
joecoolvette
  • 5660 Answers
SOURCE: hooking power supply back to
Let me look around for you.
The plastic front of the computer is the Front Panel. The area of pins on the motherboard that the wires from the Front Panel attach to, is the Front Panel header.
Sometimes there are two Front Panel headers.
This information may be tough to find.
What is needed is the manufacturer name and model number, off of the motherboard.
There were several different motherboard manufacturers used, and several different variations.
I'm going to post two links that may help you with identifying the motherboard manufacturer, and model number.
Look in the middle of the motherboard, around the edges, and in-between any expansion slots on the motherboard, for identifying nomenclature.
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWTHRASHER&eq=&Tp=
http://www.pcpartsohio.com/gateway.aspx?c=2&s=91
Going further, there is a motherboard chipset on the motherboard.
The motherboard chipset consists of the Northbridge chip, and the Southbridge chip.
The Northbridge chip will be covered with an aluminum finned Heatsink. It's identifying model number/letters will be covered.
The Southbridge chip usually does not have a Heatsink. It's model number/letters will be easily identifiable.
The Northbridge chip and Southbridge chip are installed in a mated pair.
A specific Southbridge chip will be used with a specific Northbridge chip.
This means that identifying what Southbridge chip is used will lead us to what Northbridge chip is used, without removing the Heatsink off of the Northbridge chip.
This shows you a motherboard diagram, detailing how the motherboard chipset is connected to the rest of the motherboard,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
This general example of an average motherboard shows you the Northbridge chip, and Southbridge chip,
http://en.wikipedia.org/wiki/File:MicroATX_Motherboard_with_AMD_Athlon_Processor_2_Digon3.jpg
Looking in the middle of the motherboard you will note a bl;ack square Heatsink that looks like a meat tenderizer.
This is the Heatsink over the Northbridge chip.
To the left of the Northbridge chip, and to the left of the ram memory slots, is the Southbridge chip.
It has VIA on it in white letters.
State any identifying letter/numbers that you see on the motherboard.
Please state in a Comment.
Regards,
joecoolvette
Posted on May 29, 2011
Lighting hit my gateway computer, now cant get on line
It's a wonder it works at all, you do not have a surge protector? You may have fried the ethernet card. I suppose you could get a wireless access point and a wireless card or wireless USB device for the computer. Are you sure thats all you lost?
Nov 20, 2012 | Gateway 310 S PC Desktop
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
I would like a motherboard and memory
All of these components may be purchased from a computer store. Alternatively search classified ads such as Gumtree and e-bay.
Take care!
damnor01
Apr 26, 2012 | Gateway 310 S PC Desktop
Where is located the sound card for gateway 310 x h computer
Go to http://support.gateway.com/s/PC/310_Series/2800350/2800350rv.shtml
The sound card is part of the motherboard - the three small jacks (pink, yellow (green?) and blue) just below the USB/network ports are for the sound card functions. Pink = Microphone, Yellow (Green) = audio out, Blue = audio in.
There is also an audio out in the front of the computer for headphone output.
Dec 24, 2010 | Gateway 310X PC Desktop
Gateway computer 310 series wont power up when
Good Luck,
NOLA Tech
Jan 29, 2010 | Gateway 310 S PC Desktop
Red light on motherboard; cpu fans runs and stops
very little info there...but it could be a cpl things.Most likely is power supply may be going bad,next, memory(altho less likely) or Mobo itself is failing
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Gateway 310 S PC Desktop
I hope that helps.
Jul 09, 2009 | Computers & Internet
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
May 17, 2009 | Gateway 310 X (310XSP) PC Desktop
Monitors wont work
Nov 13, 2008 | Gateway 310 S PC Desktop
Gateway 310 S PC Desktop Logo
193 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
