Question about George Foreman GV5 Indoor Grill
The Green light never comes on.The grill gets hot and Worked well.
    Problem Solver:
  • 50 Answers
Sound like the light is burnt out or on the inside the wire came loose.
Posted on Jun 20, 2008
My george foreman grill will not power on
Check for power at the outlet where you plugged it in. Plug in a small lamp, if it doesn't light could be tripped breaker or blown fuse. I am assuming there is no switch for the outlet. With the lamp still plugged in and on plug in the grill and try to turn on. If the lamp goes off or dims noticeably, you have an electrical problem, contact your electrician. If the light does not dim and it does not get hot take to repair shop.
Oct 27, 2015 | George Foreman GR10AWHT Indoor Grill
Our Kenmore Gas Grill Elite (bought in 2007) has not worked in 3+ years. It ran out of its warranty and then the problems began. It was converted to natural gas and from one day it was really hard to...
Question, when you pull off the knob do you see a screw on the front of the valve? Since the grill was converted, there are times where manufacturers use gas specific valves and the screw is there as an adjustment. Let me know.
Mar 22, 2017 | Kenmore Grilling
I have my Weber Q grill hooked up to a large propane tank rather than the small tube type. It worked fine for a few weeks but now the grill only gets medium hot. Not hot enough to cook anything really. ...
Seems as if your grill is suffering from "Clogged Burner Syndrome". But, don't despair, it's easily solved by removing and thoroughly cleaning the burners or "coil" as you called it. Also, pay particular attention to the venturi valves on the open end of the burner. Spiders like to build nests in them. The venturi valve will look like a slot on the right and left of the burner tube, where it fits over the burner orifice. It's really a good idea to perform this routine maintenance, at the start of each grilling season.
When it comes to gas grills, it's like Benjamin Franklin said, "Cleanliness is next to Godliness."
Hope this helped you solve the problem. Happy Grilling!!
Jun 02, 2011 | Weber Q Grill
All of the sudden my grill will only heat up to around 350 degrees. It is about a year old and has worked flawlessly up till now. It lights and the flames seem to be coming out of all burners but just...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 03, 2010 | Weber SPIRIT E-210 (NG)
I have a George Foreman Grill Model GRP99 Series. When I plug it in the panel does not light up. It appears to be heating. I can not tell how hot it gets because the panel is not lite.
the indicator light doesn't have anything to do with how hot the grille gets,that is preset by an internal thermostat and the light just comes on when that temperature is reached, more than likely the miniature neon bulb that light is burnt out, any appliance repair shop can replace this bulb for you
Jul 30, 2010 | George Foreman GRP99 Indoor Grill
Oxford grips
I KNOW EIGHT PEOPLE ALL HAVE THE SAME PROBLEM WITH DIFFERENT MAKES (THEY DONT WORK) INVEST IN A GOOD PAIR OF GLOVES.
GOOD LUCK.
Feb 08, 2010 | 2001 Triumph Triumph Bonneville
Propane Problems
The salesman at ACE Hardware told me I needed a grill tip cleaner. Seems the outflow valve from the tank can get crusted and there is a device called a gril tip cleaner that can help restore the gas flow to a higher level.
Jan 02, 2008 | Ducane 455 inch 2 - 3 Burner with...
Grill will not heat to high
I took the section of the grill that wasn't heating apart, in this case the bottom part, and I discovered the wire had simply come loose from the connector. I put the wire back on and tightened it now it works great.
Dec 05, 2007 | George Foreman G5 Indoor Grill
Grilling machine
you could check mouser.com or digikey.com for electrical parts
Mar 01, 2007 | George Foreman GR10ATMR Indoor Grill
George Foreman GV5 Indoor Grill Logo
64 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
