Question about Toshiba CN36V51 TV
Picture has hour glass shape - Toshiba CN36V51 TV
  • 4,472 Answers
Most likely there is either a bad solder joint or a bad resistor. I would take the tv apart and examine the circuit board for any bad solder joints. Then just add some solder to the joint and you should be good to go. If you can't find any bad solder joints then it will take a lot more troubleshooting with a multi-meter to figure out the cause of the problem.
Thank you,
Lee
Posted on Nov 15, 2010
The picture on my Sony is shaped like an hour glass
There is an apparatus on the back of your picture tube called a yoke.This distributes your picture on your pic tube uniformly.If this or the circuits enabling it malfunction,then you will get distortion-namely an hour glass shape.Tv has to be trouble shooted.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Picture looks like hour glass.
You're probably talking about bad convergence. Probably Convergence power board. Only $20-$30 from encompassparts. com, if still available.
Apr 17, 2010 | Televison & Video
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WS-55807 hour glass shaped picture
If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual and try by yourself see link
Mar 04, 2008 | Mitsubishi WS-55807 TV
Hour Glass Picture
can you put it other way i did not understand what you want to say & que is not complete.
Sep 25, 2007 | GE 31GT660 TV
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
Tv picture shaped like hour glass
Big cap in the regulation ckt is bad. Depending on model could be various values, a shop could use their ESR meter to find and replace it.
Jul 03, 2007 | GE 31GT740 31" TV
Picture shaped like hour glass
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Toshiba CN36V51 TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
