Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have a kodak ESP-3 all in one printer that has a new black, and new color ink cartridge, and the printer does not print any colors. only prints black, grey, and a litte bit of greenish tint.
  • Kodak Master
  • 32,281 Answers
Inkjet printers do not like being left unused.
The color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Posted on Nov 15, 2010
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
My kodak esp 3 won't doesn't recognize the new black ink we put in
I'm having this same problem with both black and a color cartridge. I see the small scratches, so looks like they are connecting all right. The new cartridges are Kodak brand, so that's not the problem.
I'll try calling them about the print head if that might be the problem.
Nov 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
USELESS! I guess the life of an ESP 3 is up to a year, because after Kodak replaced my first ESP 3 with a second, I'm now having issues. It's also MOST frustrating that if one cartridge is empty and...
Regarding the empty ink cartridges, ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Regarding the printer not being able to detect the size of the paper, you probably need a firmware update. Here is the support information from Kodak website.
And I have to agree with you, printers don't have a very long life cycle, but you should get at least 2 years out of it! Good luck!
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How can I over ride my ink level tracker on the Kodak ESP 7 printer? The printer must be using a counter because I never print in color but my color cartridge keeps showing that it is going down. ...
The Kodak printers are designed in such a way so as to work with combination of Both color and black ink..In other printers,the prints are not that sharp,but In kodak printers color are awesome because even if we print black and white,the color from the color ink is also taken to give you those lifetime prints.Unfortunately There is no way to overcome this ink indicator.You cans et the preferences in the printer settings to print in black and white in your computer .
Dec 30, 2009 | Kodak ESP 5 Printer
Ink problems
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 01, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Colors won't print
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
527 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
