Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Leaky 4 HP hot tub pump seal AO SMITH motor, pump
Leaky 4 HP hot tub pump seal AO SMITH motor, pump Model DJAAYGB-9113 Code 1H99Y I have removed the impeller, and it looks like the spring loaded face seal is worn. How do I replace this part, and where do I find it?
  • 310 Answers
If you have removed the impeller this is what you need.
Part number for your shaft seal is : 37400-0028s
Here is a link to the manual on how to install / remove this seal on this pump:
http://www.hottubs.com/content/pdf/Sta-Rite_Dura-Jet_S377(9-12-03).pdf
Refer to page 9.
This seal can be purchased anywhere on the internet. Just do a google search with only the part number. Many suppliers will come up. If you have trouble, I have a few and can make an E-bay sale for one.
Posted on Nov 15, 2010
Testimonial: "Thanks, and especially for the link to the manual. This is exactly what I needed. Mark"
What size bearings does AO smith motor 8d-10-1n11cb use
better off replacing whole motor or pump if bearings bad soon seals because they got hot less headache replace whole pump
May 27, 2016 | AO Smith Pool & Spa
Help! Just opened my pool and the pump/motor (which is only 2 years old) is very noisy. Sounds like it could be the bearings. Do call someone to the house, disconnect and take to a repair shop, ord
Disassemble the pump to the point where you can see the whole impeller. Then turn the power back on to verify that it is the bearings, and not trapped debris causing the noise. If it is the bearings the short answer is to replace the motor.
Bearing failure is usually related to a leak at the pump seal. This results from either a faulty seal installation, or the pump running excessively hot (from running w/o water).
When replacing the motor carefully examine the seal plate (where the seal is set) front and back for any cracks or deformity. If the new seal doesn't set exactly, it will leak.
Apr 03, 2013 | Smith AO Pool Pump Motor
Need replacemant bearings for 1 hp AO Smith pool pump motor
6203 2rs c3 are the bearing you need. best to have a pro do it. should cost around $75, thats what I charge /w free shaft seal. remember to prime the pump after any repair
Mar 27, 2013 | AO Smith 1 hp 3450rpm 56J Frame 115/230...
If AO Smith 1.5 HP pool pump mootor is turning the wrong direction could that be the reason for not priming. If so how do you change the direction of spin?
these motor have been known to do this, you could have the capacitor checked or replaced, it might be a bad motor.. i would look to see that the shaft seal is good (new) and no suction leaks and that the pump has been primed.. if not its time 4 a new shaft seal.. it only takes a short time to burn up the shaft seal
Feb 19, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
First stage of my 2 speed hot tub ao smith pump doesnt work electrcian says switch is not lined up right?
these are a hard motor - pump to work on. i would take it to your local pool pump motor repair guy who has free motor testing , un plug the motor from the control box not at the motor, if you do take pictures or make a diagram of each wires place ! if you hook it up wrong you can BURN THE MOTOR UP AND THERE IS NO FIX'N IT. sept for a new motor $$$ yuk .take the pluming lose and leave the pump on the motor.... good luck .. hope i was a little help if so please leave feedback .. Jay THE PPMRG FLORIDA
Aug 01, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the...
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
May 31, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Motor has died, how to disconnect from pump. 2
The thru-bolts hold it to the seal plate and the impeller is threaded onto the shaft.
Aug 09, 2009 | AO Smith Pool Pump Motor Hayward 2 Speed...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
435 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
