Question about Garden
Topcon rl-vh2g laser how do i use the smartscan to put the laser line where i want it. and how do i stretch the laser line
2 Suggested Answers
  • 3 Answers
SOURCE: topcon rl-hb wont level
One guy says disassemble and clean the mirror on the turret
Posted on May 18, 2013
What is the slope buttons used for
If you have the standard RL-H3C then there are 3 buttons. Starting from the left there is the "height alert" then "manual" then "Power".
Height alert is a function that after the laser levels and spins monitors the position of the laser. If the laser moves more then a tiny amount then the height alert function is tripped, and the laser flashes it's lights and stops spinning (or spins slowly) to let you know the base line position of the laser has changed. Pressing the height alert button twice shuts this mode off.
Manual mode means after the laser is leveled, it completely ignores the level vials. You can turn the laser any way you want to and it will always spin and not cause any errors.
Power is self explanatory.
If it's a RL-H3CS then it has two arrow buttons, that when in manual mode, allot one axis of the laser to be manually adjusted up and down to do a manual slope.
Sep 22, 2014 | Topcon Rlh3c Rotating Laser Level W...
How do I calibrate a topcon laser ?
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series. calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-0.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-2.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-5.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-9.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-14.jpg
Aug 11, 2014 | Topcon Rotating Builders Red beam Laser...
No laser beam on topcon rlh3c laser level
Take this to a survey/laser repair shop, preferably one that does not charge for estimates.. The laser diodes on the RL-H3C is not serviceable. It requires the lens barrel assembly (or telescope tube unit, i don't remember what they call it in these). It's unreasonably expensive, and will likely be a write off. It may however be the main circuit board, but likely not. Be prepared to replace this unit.
Feb 25, 2014 | Topcon Rlh3c Rotating Laser Level W...
Weak beam .can barely see espically when sun is shining.
How old are the batteries? The company appears to be proprietary and does not release much information.
Sep 02, 2013 | Topcon tpl4b pipe laser w/remote,red
Laser won't turn on
Likely it's dirty battery contacts. Clean the contacts on the battery tray, and the coil springs in the laser, and it should start.
If not open the laser, reinsert the battery tray with good batteries and test the voltage at the battery connector at the rear of the laser.
Check for signs of water damage or corrosion.
short out the power switch, to make sure it's not the problem.
The switch circuit board, power connectors, battery tray, and motors are the only electronic parts still available for these lasers, and that is only because they share them with the RL-H3A, which was only discontinued in 2011. If none of the above will make it turn on, you'd need to find used parts, and try and rebuild it.
Jan 28, 2013 | Topcon Rl-hb Rotating Laser Level W/ls-70b
My Topcon RL-H3A continually attempts to levvel its self then runs for a short while then goes into a like stand by mode with the out of balance off light (red) and Power light (Green) flashing Thisn...
Sound like the laser diode is failing. It's power is likely just strong enough to get the level position right, then dims as it runs. The unit, no longer seeing the laser, decides it's out of level and stops. Or the oil in the compensator is leaking, and the same process is happening. Unfortunately the replacement part is not economical to replace.
Dec 02, 2010 | Topcon Rlh3a Long Range Rotating Laser...
Have older Topcon RL-H ,someone picked the unit up and put it over his shoulder while it was still running.Now it will level and then run about 1o seconds then either stop and re level or just shut off
It's likely leveled past it's leveling limit. You can try pulling out the 4 screws holding the bottom out, and very carefully opening the bottom of the laser. The main circuit board is attached to the base, so do not pull apart hard or too far. Next mark all the connectors on the board, and what wires go to them, and pull them all out. Remove the bottom completely and you should see the leveling assembly. Move the gears so the leveling system is more centered. Put it back together and test. If it doesn't work then you have something mechanically out of alignment or electronic values have messed up, and you have have to bring it somewhere for repair.
Oct 01, 2010 | Topcon Rlh3c Rotating Laser Level W...
I NEED THE UNLOCK CODE FOR THE PRICE IS RIGHT ON HP GAMES AND HOW SHOULD I ENTER IT
i need to find the unlock code for the price is right (im out of wildcoins and i want to play some more)!!!
Aug 24, 2009 | Cross Topcon 57079 Rl VH3D Value Priced...
Garden Logo
222 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
